Home > Forums > OpenFOAM Running, Solving & CFD
simpleFoamResidual
Old   October 14, 2013, 06:17
Question simpleFoamResidual
M. Montero
be_inspired is on a distinguished road
Hi all,
My question is related to the utility simpleFoamResidual implemented into OF1.6ext. According to the code, it analyze the momentum equation. The perfect situation, I think, would be that uResidual is equal "0".
The attached convergence is OK but the maxium uResidual that I obtain is around 76 and the mean around 0.09. In other different mesh, the maximum uResidual obtained was around 2000.
Could anyone tell me how much is a high value of uResidual? Is possible to have a physical meaning about the uResidual? If I have higher values than 0.05, for example, does it tell me that it is require to refine the mesh?
I would appreciate any help. I would like to have a criteria to know if current mesh resolution is enough or not for my purposes without doing a mesh resolution analysis in detail. Thank you very much.
            Info<< "    Calculating uResidual" << endl;
            volScalarField uResidual
                IOobject
                    "uResidual",
                    runTime.timeName(),
                    mesh,
                    IOobject::NO_READ
                mag
                    fvc::div(phi, U)
                  + fvc::div(turbulence->R())
                  + fvc::grad(p)
Time = 3000
DILUPBiCG:  Solving for Ux, Initial residual = 1.48121e-08, Final residual = 6.66887e-11, No Iterations 2
DILUPBiCG:  Solving for Uy, Initial residual = 1.09835e-05, Final residual = 1.32954e-08, No Iterations 2
DILUPBiCG:  Solving for Uz, Initial residual = 1.96974e-05, Final residual = 3.96294e-08, No Iterations 2
GAMG:  Solving for p, Initial residual = 0.00085226, Final residual = 4.08688e-05, No Iterations 8
time step continuity errors : sum local = 2.32144e-10, global = -6.39797e-11, cumulative = 2.45607e-07
DILUPBiCG:  Solving for epsilon, Initial residual = 2.62941e-07, Final residual = 2.54438e-10, No Iterations 1
DILUPBiCG:  Solving for k, Initial residual = 9.73059e-07, Final residual = 3.07595e-10, No Iterations 2
ExecutionTime = 7790.51 s  ClockTime = 7792 s
be_inspired is offline   Reply With Quote
Old   October 14, 2013, 06:26
akidess's Avatar
Anton Kidess
I don't think this tool can replace a mesh sensitivity study. All it tells you is that a solution is converged, not that it is converged and accurate.
*On twitter @akidTwit
*Spend as much time formulating your questions as you expect people to spend on their answer.
*Join the OpenFOAM stackexchange Q&A site: http://area51.stackexchange.com/prop...oHPxcPqde7HtA2
Old   October 14, 2013, 07:10
M. Montero
I am trying to link Dr.Jasak Thesis about error estimation with my case and to know if it is needed to refine the mesh once convegence has been "obtained" (residuals).
Chapter 5 is dedicated to the adaptative mesh refinement to reduce the numerical error up to the desired level. There should be a criteria ( I hope that) about when the error (uResidual) has been reduced enough to minimize the numerical error.
Thread Tools
Trackbacks are On
Custom Boundary Condition with OpenFOAM trusharg OpenFOAM Programming & Development 41 April 18, 2015 17:33
simpleFoamResidual File OpenFOAM Running, Solving & CFD 2 October 4, 2013 10:50
simpleFoamResidual error val46 OpenFOAM 1 October 19, 2010 02:47
