October 19, 2013, 17:11 |
Stokes Flow Simulation
Angus Hendrick
Rep Power: 12 |
I am trying to find the steady-state velocity field for laminar flow transverse to a random array of parallel cylinders using simpleFoam in OpenFOAM 2.2.1. I am using empty boundary conditions on faces normal to the cylinder axes and cyclic boundary conditions for the other faces. The flow is supposed to be driven by gravity acting in one of the two cyclic directions.
The simulation does not work. It converges to a velocity that approaches 0, if seeded with non-zero velocities (as the attached case does). It appears that the gravitational term is ignored, though I have included "g" in the constants directory. The case is zipped here. I'm sure I'm doing something stupid. Any help, especially if it wittily points out just how stupid I am, is much appreciated. |
October 20, 2013, 23:58 |
#2 | |
mohsen kh
Rep Power: 14 |
take a look to this project specially page 23 I think it would be helpful for your case http://www.diva-portal.org/smash/get...T01.pdf best regards Mohsen |
October 21, 2013, 21:00 |
Angus Hendrick
Rep Power: 12 |
Thanks for the response to my question. I read the paper you linked, and while it is broadly related (i.e., flow around cylinders), I don't find a discussion of the problem I am having. That is, in my case I need to generate body-force (i.e., gravity) driven flow.
October 22, 2013, 01:56 |
Bernhard
Rep Power: 21 |
There is something physically wrong with what you expect. You have a fluid with constant density. How would gravity act on it? E.g.: in a bottle of water there is no movement.
October 22, 2013, 20:21 |
Angus Hendrick
Rep Power: 12 |
The simulation is set up so that it has cyclic boundary conditions top and bottom. With gravity acting downward, I expect that all the fluid will fall, exiting the bottom and re-entering at the top. Because of the no-slip boundary conditions on the cylinders within the domain, I expect that it will eventually reach a steady state where the momentum added by gravity is equal to the momentum lost at the solid surfaces.
I recognize that if gravity is added as a modified pressure, then there will be no flow, and so an explicit body force term may be necessary. I don't know how to add this if it is. Last edited by angushendrick; October 25, 2013 at 20:29. |
November 3, 2013, 15:33 |
Solution using a vectorSemiImplicitSource
Angus Hendrick
Rep Power: 12 |
Putting the following in system/fvOptions is my current approach. It seems to work.
momentumSource1 { type vectorSemiImplicitSource; active true; selectionMode all; vectorSemiImplicitSourceCoeffs { volumeMode absolute; injectionRateSuSp { U ((1e-6 0 0) 0); } } } |
Display Modes | |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 17:02 |
Domain format problem on airfoil flow simulation | andrenonaka | CFX | 14 | December 7, 2015 00:42 |
Query regarding temperature distribution in Solidworks flow simulation | syarif | FloEFD, FloWorks & FloTHERM | 3 | February 27, 2013 05:22 |
problems in synthetic jet flow simulation | jackxu | FLUENT | 0 | December 2, 2012 09:12 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 21:31 |
