Use direct numerical simulation on engineFoam
Hi everyones,
I'm a new user and I'm working on the tutorial engineFoam to simulate the flow around the valves, but i need to change the Reynolds number at around 50 or 100. For that i have to change the viscosity and the pitch of the mesh. So i was looking at the transport properties file but i didn't found it. If someone can explain to me how to proceed cause i really have no idea. Thanks, Maxime. |
I make a copy of the engineFoam solver and modify the Ueq.H file like this:
PHP Code:
I also add in combustion properties the value of nu. But when i'm running i got an error: " can't found engineFoamdns". If someone has an idea of the source of the problem or tell me what i'm doing wrong ? Thanks you! Maxime. |
