supersonic case with kOmegaSST
Like Tree1Likes
  • 1 Post By wyldckat
Old   October 18, 2013, 23:58
Default supersonic case with kOmegaSST
Fluid Dynamics
cfd.with.openfoam is on a distinguished road
I am dealing with a supersonic case and I have a BL resolved grid (i.e y+ < 1 everywhere). Turbulence model being employed is kOmegaSST and the BCs that I am using for k, omega and mut, at the walls are -
k - 1e-10 (simply because viscosity takes charge at the wall)
omega - compressiblemegaWallFunction (not sure about this)
mut - 1e-10 (no turbulence at the wall so no turbulent viscosity either)
Questions -
1. Henry mentioned in a couple of posts that if y+<1 then one should use a lowRe model. Another thing that he mentioned somewhere was that the kOmegaSST implemented in OpenFOAM (by the way right now I have OF-2.2.2) is not suitable for wall resolved calculations because some kind of damping is not there. So the question is - Is it OK to use kOmegaSST with y+<1 everywhere or not with OF-2.2.2?
2. If it is OK to use kOmegaSST in this scenario; then are the boundary conditions for k, omega and mut ok here or not?
Thanks very much.
I have read several threads and posts but these things are not clear at all to me.
cfd.with.openfoam is offline   Reply With Quote
Old   October 23, 2013, 08:48
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
I am not sure if your post is correct in this subforum because your question is not depending on bugs but rather on turbulence models and it s wall functions.
If you use wall functions for the turbulent variables then you should have y+ > 12.4 ... have a look at different literature (for example Ferziger).
If you have y+ round about 1 then you do not Need wall functions because you are solving the whole wall field direct (viscouse sublayer). If you are using wall functions you use the logarithmic wall function to get the effects of the viscous sublayer.
So your omega wall function is wrong because you have y+ < 1.
You k value does not make sence to me?!
If i am wrong please correct me (it s a long time ago I had the theoretics).
Regards Tobi
PS: @admin - maybe its better to move the last two Posts to a new thread to clean this on.
Tobi is offline   Reply With Quote
Old   October 26, 2013, 13:18
Retired Super Moderator
Bruno Santos
FYI: I've moved the two posts indicated by Tobi from the thread http://www.cfd-online.com/Forums/ope...komegasst.html to this new one you are currently reading
Tobi likes this.
extracting outlet velocity profile from one case to another case's inlet tonggysun OpenFOAM 2 September 13, 2013 04:19
Numerical error or case error? Flow in a 3D pipe fsalvucci OpenFOAM 40 January 30, 2013 07:10
Flux update during an MPI run between decomposed case parts? scott OpenFOAM 0 July 21, 2010 20:47
looking for a test case, DES, Supersonic flow kaarthik Main CFD Forum 0 June 7, 2007 05:49
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
