-   -   interFoam ask for a value in a nutkRoughWallFunction (http://www.cfd-online.com/Forums/openfoam-solving/125754-interfoam-ask-value-nutkroughwallfunction.html)
avigrod October 30, 2013 09:01
I have defined a rough wall bc using nutkRoughWallFunction, in this way (0/nut):
object      nut;
boundaryField
    wall
        type            nutkRoughWallFunction;
        Ks              uniform 0.0001;
        Cs              uniform 0.5;
Following instructions from $FOAM_SRC/turbulenceModels/incompressible/RAS/lnInclude/nutkRoughWallFunctionFvPatchScalarField.H
Example of the boundary condition specification:
    \verbatim
    myPatch
        Ks              uniform 0;
        Cs              uniform 0.5;
    \endverbatim
When running interFoam it shows the following error message:
0/nut.boundaryField.wall from line 26 to line 28.
    From function fvPatchField<Type>::fvPatchField(const fvPatch& p,const DimensionedField<Type, volMesh>& iF,const dictionary& dict,const bool valueRequired)
    in file /home/opencfd/OpenFOAM/OpenFOAM-2.2.2/src/finiteVolume/lnInclude/fvPatchField.C at line 162.
FOAM exiting
lines 26-28 are the ones I paste here within the 0/nut file.
Why is it asking for a value field, if the wall function does not need it? If I put any value, Would it be used for anything? I mean, if I add a "value uniform 0;", it won't influenced anything, will it?
Thank you in advance!
olivier78 August 13, 2014 08:46
same problem here
tomf August 14, 2014 03:49
It is just needed for the first iteration and will be overwritten afterwards, so just put uniform 0, or maybe a small value.
