-   OpenFOAM Running, Solving & CFD (https://www.cfd-online.com/Forums/openfoam-solving/)
-   -   pimpleDyMFoam -- lowered viscosity -- time step continuity errors getting large (https://www.cfd-online.com/Forums/openfoam-solving/125800-pimpledymfoam-lowered-viscosity-time-step-continuity-errors-getting-large.html)
pbachant October 31, 2013 09:17
I'm working on some cases with pimpleDyMFoam, which I have gotten to mesh and solve fairly well, but then when I go to drop nu from 1e-6 to 6.7e-7, I am getting time step continuity errors that go up into the 6000 range after a few seconds. This then sets my deltaT so low that the solution effectively halts. Any ideas why this would happen?
Artur November 4, 2013 04:37
My guess would be something happening with either:
div((nuEff*dev(T(grad(U)))))
or with the turbulent quantities. So either fvSolution or fvSchemes file. Perhaps changing to a lower order scheme, different equation solver, adding underrelaxation or pushing down your tolerances would prevent it from blowing up. It would all depend on how the process actually takes place - showing your log file would help a bit in determining what is actually going on.
Are you using the same mesh for both viscosities? What kind of moving mesh are you using?
All the best,
A
