becker bubble column with twoPhaseEulerFoam
Old   March 6, 2012, 03:28
Default becker bubble column with twoPhaseEulerFoam
Gerhard Holzinger
GerhardHolzinger will become famous soon enoughGerhardHolzinger will become famous soon enough
I am quite new to OF and I am trying to simulate a bubble column. The setting is described in publications of S. Becker who did measurements as well as simulations.
In Pfleger et al. (1999) it is stated that the continuous phase (water) is modelled laminar or turbulent while the dispersed phase (air) is always modelled laminar.
How is it possible in OF to model only one phase turbulent?
Pfleger et al. further conclude that modelling the continuous phase fits experimental data better than modelling it laminar.
I did a simulation modelling all phases laminar and also modelling all phases turbulent. In my solutions only the laminar case shows the expected oscillation of the bubble plume.
GerhardHolzinger is offline   Reply With Quote
Old   August 26, 2012, 11:26
Default Did you solve this issue ?
chittipo is on a distinguished road
why don't there are any oscillations with turbulence ?
chittipo is offline   Reply With Quote
Old   August 30, 2012, 09:01
Mat
Mat_fr is on a distinguished road
I suppose it's quite late for answering, but anyway, I think you should play with the turbulent response coefficient Ct in transportProperties to differentiate the turbulence behaviour of both phases.
Best,
Mat
Mat_fr is offline   Reply With Quote
Old   November 21, 2013, 12:45
Jonas L. Ansoni
Jonas Ansoni is on a distinguished road
Hi!!
I'm trying to use the twoPhaseEulerFoam to solve a problem as described on the case1 file (Download files). However, I am not able to get results because deltaT is too small.
Courant Number mean: 1.76078e-05 max: 0.215443
Max Ur Courant Number = 0.517251
deltaT = 1.8695e-108
--> FOAM Warning :
    From function Time::operator++()
    in file db/Time/Time.C at line 937
    Increased the timePrecision from 6175 to 6176 to distinguish between timeNames at time 0.0223074
Time = 0.02230736969663438262756471885950304567813873291015625
DILUPBiCG:  Solving for alpha, Initial residual = 1.24818e-08, Final residual = 3.00309e-20, No Iterations 1
Dispersed phase volume fraction = 0.000706992  Min(alpha) = -2.22442e-06  Max(alpha) = 0.500588
DILUPBiCG:  Solving for alpha, Initial residual = 1.10523e-09, Final residual = 3.94419e-24, No Iterations 1
[7] #0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[7] #1  Foam::sigFpe::sigHandler(int) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[7] #2   in "/lib/libc.so.6"
[7] #3  Foam::GAMGSolver::scalingFactor(Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double> const&, Foam::Field<double> const&) const in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[7] #4  Foam::GAMGSolver::scalingFactor(Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double>&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[7] #5  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[7] #6  Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[7] #7  Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam201/platforms/linux64GccDPOpt/lib/libfiniteVolume.so"
[7] #8
[7]  in "/opt/openfoam201/platforms/linux64GccDPOpt/bin/twoPhaseEulerFoam"
[7] #9  __libc_start_main in "/lib/libc.so.6"
[7] #10
[pegasus:03885] *** Process received signal ***
[pegasus:03885] Signal: Floating point exception (8)
[pegasus:03885] Signal code:  (-6)
However, I'm generating the mesh using the SALOME (tetrahedral - NETGEN) (checkMesh ok). I tested a tetrahedral mesh in the same Gerhard's example and the problem occurred too.
Someone could tell me if the problem is the type of mesh or have another problem in my test case?
Best regards,
Jonas
Jonas Ansoni is offline   Reply With Quote
Old   November 25, 2013, 01:53
Dongyue Li
sharonyue is on a distinguished road
Originally Posted by Jonas Ansoni View Post
Hi!!
--> FOAM Warning :
[7] #8
[7] #10
Best regards,
Jonas
I think twoPhaseEulerFoam cant solve on tet mesh. You have to generate a hex mesh.
Long time ago I make a very simple test. All the settings are the same expect that one is tet the other is hex. As your expect, the tet one crushed.
sharonyue is offline   Reply With Quote
bubble column, twophaseeulerfoam
Bubble Column Modelling dlaw FLUENT 24 October 31, 2017 06:01
bubble column ken FLUENT 1 June 30, 2013 01:18
Modelling a Water-Air bubble column GerhardHolzinger OpenFOAM Running, Solving & CFD 1 February 28, 2012 04:12
bubble rising in a column swamysrikanth Main CFD Forum 2 September 27, 2010 08:59
Help required for CFD simulation of Trayed Bubble Column using Fluent art705 Main CFD Forum 0 July 15, 2009 04:04
