SimpleFoam convergence problem with really simple simulation
Old   November 6, 2013, 01:04
Default SimpleFoam convergence problem with really simple simulation
India
mayank.dce2k7 is on a distinguished road
Hi Foamers,
I am facing SimpleFoam convergence problem with a really basic simulation i.e steady state flow simulation in a single bifurcation tube by specifying fully developed velocity profile at inlet(using swak4Foam toolbox).
After digging through various threads related to convergence problem, I tried changing divergence schemes, played with relaxation factors and tried grid refinement but nothing helped. Situation became so bad the case is not converging using first order upwind scheme let one second order schemes. Below are some details of my case set up:
1.) Mesh is generated on ANSYS ICEM using tetrahedral and prism elements. My model contains about 0.6 million elements.
2.) checkMesh result:
Create time
Create polyMesh for time = 0
Time = 0
Mesh stats
faces: 1354300
internal faces: 1310124
cells: 603415
boundary patches: 4
point zones: 0
face zones: 1
cell zones: 1
Overall number of cells of each type:
hexahedra: 0
prisms: 250764
wedges: 0
pyramids: 0
tet wedges: 0
tetrahedra: 352651
polyhedra: 0
Checking topology...
Boundary definition OK.
Cell to face addressing OK.
Point usage OK.
Upper triangular ordering OK.
Face vertices OK.
Number of regions: 1 (OK).
Checking patch topology for multiply connected surfaces ...
Patch Faces Points Surface topology
WALL 41794 20988 ok (non-closed singly connected)
INLET 1047 787 ok (non-closed singly connected)
OUTLET1 666 523 ok (non-closed singly connected)
OUTLET2 669 528 ok (non-closed singly connected)
Checking geometry...
Overall domain bounding box (-0.108855 -0.161689 -0.01905) (0.108855 0.127 0.01905)
Mesh (non-empty, non-wedge) directions (1 1 1)
Boundary openness (6.33376e-17 2.25628e-17 -1.46543e-16) OK.
Max cell openness = 3.10378e-16 OK.
Max aspect ratio = 18.7479 OK.
Minumum face area = 1.85691e-07. Maximum face area = 4.16397e-06. Face area magnitudes OK.
Min volume = 1.38121e-11. Max volume = 2.46223e-09. Total volume = 0.000347757. Cell volumes OK.
Mesh non-orthogonality Max: 76.7538 average: 13.2348
*Number of severely non-orthogonal faces: 1.
Non-orthogonality check OK.
<<Writing 1 non-orthogonal faces to set nonOrthoFaces
Face pyramids OK.
Max skewness = 2.96438 OK.
Coupled point location match (average 0) OK.
Mesh OK.
End
3.) 0/U file
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField  uniform (0 -0.172 0);
boundaryField
    INLET
       type            groovyBC;
       variables "r2=(pow(pos().x,2)+pow(pos().z,2));R2=pow(0.019,2);para=-((R2-r2)/R2)*normal();";
       valueExpression "2*0.172*para"; //where 0.351 is the average velocity
       value        uniform (0 0 0);
    WALL
        type            fixedValue;
    OUTLET1
        type            flowRateInletVelocity;
        flowRateExpression "0";
        flowRate swak {
            variables "phi1{INLET}=-0.52*0.172*sum(area());";
            expression "phi1"; // volume flow going out of domain from outlet 1 which 0.52 times that at inlet
            valueType patch;
            patchName OUTLET1;};
     value           uniform ( 0 0 0 );
    OUTLET2
      type  zeroGradient;
2.) 0/p
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    INLET
        type            zeroGradient;
    OUTLET1
      type            zeroGradient;
    OUTLET2
      type            fixedValue;
      value           uniform 0;
    WALL
        type            zeroGradient;
3.)
fvSchemes
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         steadyState;
gradSchemes
    default         Gauss linear;
    grad(p)         Gauss linear;
    grad(U)         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      Gauss upwind;
    div(phi,nuTilda) Gauss upwind grad(nuTilda);
    div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         none;
    laplacian(nuEff,U) Gauss linear limited 0.333;
    laplacian((1|A(U)),p) Gauss linear limited 0.333;
    laplacian(DnuTildaEff,nuTilda) Gauss linear limited 0.333;
    laplacian(1,p)  Gauss linear limited 0.333;
interpolationSchemes
    default         linear;
    interpolate(U)  linear;
snGradSchemes
    default         limited 0.333;
fluxRequired
    default         no;
    p               ;
4.)
|  \\    /   O peration     | Version:  2.1.1                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    p
        solver          GAMG;
        tolerance       1e-02;
        relTol          0.1;
        smoother        GaussSeidel;
        nPreSweeps      0;
        nPostSweeps     2;
        cacheAgglomeration true;
        nCellsInCoarsestLevel 10;
        agglomerator    faceAreaPair;
        mergeLevels     1;
    U
        solver          smoothSolver;
        nSweeps         2;
        tolerance       1e-02;
        relTol          0.1;
    nuTilda
        nSweeps         2;
        tolerance       1e-02;
        relTol          0.1;
SIMPLE
    nNonOrthogonalCorrectors 2;
    pRefCell        0;
    pRefValue       0;
    residualControl
        p               1e-4;
        U               1e-4;
        nuTilda         1e-4;
relaxationFactors
    fields
        p               0.9;
    equations
        U               0.1;
        nuTilda         0.2;
Any help will be appreciated!
mayank.dce2k7 is offline   Reply With Quote
Old   November 6, 2013, 04:21
India
ok, one improvement on my part. I got it converged for first order upwind scheme but still no luck with second schemes(SFDCV, linearUpwind etc). I took first order result and used it for my simulation with second order divergence scheme but with no luck.
Old   November 19, 2013, 05:28
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
Hi, did you try to use some limiters on the gradients? Sounds like this could be a problem here, since first order works and second order doesn't.
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Convergence of jet flow simulation MiraLisa FLUENT 0 August 15, 2013 04:44
SimpleFoam Convergence problem skabilan OpenFOAM Running, Solving & CFD 6 May 31, 2013 03:21
Force can not converge colopolo CFX 13 October 4, 2011 22:03
2D SST Simulation Airfoil - Convergence Problem Kraemer CFX 10 April 16, 2011 07:22
Convergence problem with simpleFoam solver on tilted channel daev OpenFOAM Running, Solving & CFD 1 December 23, 2010 16:20
