November 12, 2013, 05:43 |
k omega turbulence model
Rep Power: 12 |
Hello I'm simulating a supersonic flow with OpenFoam and I'm using the k omega SST RANS turbulence model. It's a compressible flow, I'd like to use the standard k omega turbulence model, but in the tutorial I read that I can't use the standard k omega with a compressible flow. I'm not sure of this because it's the tutorial of an old version of OpenFoam. So my question is if I can use the standard k omega with a compressible flow. I'm using the rhoReactingFoam solver. Thank you!
Fluent :- turbulence Model | prince_pahariaa | FLUENT | 9 | May 20, 2016 03:41 |
Implement an les turbulence model | pante | OpenFOAM Programming & Development | 19 | December 5, 2014 16:16 |
How to decide to Turbulence model | shipman | OpenFOAM | 2 | August 18, 2013 03:00 |
KOmega Turbulence model from wwwopenFOAMWikinet | philippose | OpenFOAM Running, Solving & CFD | 30 | August 4, 2010 10:26 |
Transition kappa omega turbulence model | mannobot | FLUENT | 0 | June 9, 2010 04:11 |
