Debugging an intermittent floating point exception |
November 8, 2013, 07:25 |
Marcus Letzel
Rep Power: 13 |
Dear FOAMers,
my pisoFoam solver modified to produce postprocessing output for LES quality control causes intermittent floating point errors (FPE). Code and error message will be posted below. It is possible to restart the crashed job from latestTime, which is up to several dozen time steps in the past, because writeInterval >> deltaT. To my surprise I noticed that this procedure has so far always been successful to overcome the time when the FPE initially occurred in the crashed job, but only to produce the same FPE at some time later in the course of the simulation. So far, the FPE has never occurred twice at the same time, although it recurs it is strictly speaking not reproducible. I see no indication to predict when the FPE will occur. Code added to createFields.H: Code:
volVectorField Uav ( IOobject ( "Uav", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::AUTO_WRITE ), mesh, dimensionedVector("Uav", dimensionSet(0,1,-1,0,0,0,0), Foam::vector(0,0,0)) ); volVectorField U2av ( IOobject ( "U2av", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::AUTO_WRITE ), mesh, dimensionedVector("U2av", dimensionSet(0,2,-2,0,0,0,0), Foam::vector(0,0,0)) ); Code:
scalar dt = runTime.deltaT().value(); if ( time > startAveraging + dt ) { Uav = ( Uav*(time-startAveraging) + U*dt ) / (time-startAveraging + dt); for ( int i = 1; i <= 3; ++i) { U2av.component(i) = ( U2av.component(i)*(time-startAveraging) + U.component(i)*U.component(i)*dt ) / (time-startAveraging + dt); } } Code:
Time = 2107.95 Courant Number mean: 0.0923695 max: 0.869684 Ubar_g = 1.7558 fMC = 1.00107 DILUPBiCG: Solving for Ux, Initial residual = 0.00387829, Final residual = 2.36e-08, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 0.0124318, Final residual = 2.63485e-07, No Iterations 2 DILUPBiCG: Solving for Uz, Initial residual = 0.0130876, Final residual = 9.39095e-08, No Iterations 2 GAMG: Solving for p, Initial residual = 0.118412, Final residual = 0.00851802, No Iterations 8 time step continuity errors : sum local = 9.43142e-07, global = -2.8715e-07, cumulative = -3.47101e-06 GAMG: Solving for p, Initial residual = 0.0124153, Final residual = 0.00732398, No Iterations 1 time step continuity errors : sum local = 8.17403e-07, global = 2.50387e-07, cumulative = -3.22063e-06 DILUPBiCG: Solving for s1, Initial residual = 0.000401176, Final residual = 8.4247e-08, No Iterations 2 DILUPBiCG: Solving for s2, Initial residual = 0.000371733, Final residual = 9.41308e-07, No Iterations 1 ExecutionTime = 14039.3 s ClockTime = 14080 s Time = 2108 Courant Number mean: 0.0923709 max: 0.873343 Ubar_g = 1.7558 fMC = 0.999099 DILUPBiCG: Solving for Ux, Initial residual = 0.00355117, Final residual = 2.59767e-08, No Iterations 2 DILUPBiCG: Solving for Uy, Initial residual = 0.0125795, Final residual = 3.48008e-07, No Iterations 2 DILUPBiCG: Solving for Uz, Initial residual = 0.0116423, Final residual = 1.20912e-07, No Iterations 2 GAMG: Solving for p, Initial residual = 0.123565, Final residual = 0.00945173, No Iterations 10 time step continuity errors : sum local = 1.05124e-06, global = 2.93489e-07, cumulative = -2.92714e-06 GAMG: Solving for p, Initial residual = 0.0139839, Final residual = 0.00829818, No Iterations 1 time step continuity errors : sum local = 9.2276e-07, global = -2.56682e-07, cumulative = -3.18382e-06 DILUPBiCG: Solving for s1, Initial residual = 0.000401261, Final residual = 9.34449e-08, No Iterations 2 DILUPBiCG: Solving for s2, Initial residual = 0.000371337, Final residual = 9.54196e-07, No Iterations 1 [0] #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [0] #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [0] #2 in "/lib/x86_64-linux-gnu/libc.so.6" [0] #3 Foam::multiply(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" [0] #4 void Foam::multiply<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) in "/home/deineruser/OpenFOAM/deineruser-2.2.2/platforms/linux64GccDPOpt/bin/XC15Heise2" [0] #5 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::operator*<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&, Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) in "/home/deineruser/OpenFOAM/deineruser-2.2.2/platforms/linux64GccDPOpt/bin/XC15Heise2" [0] #6 [0] in "/home/deineruser/OpenFOAM/deineruser-2.2.2/platforms/linux64GccDPOpt/bin/XC15Heise2" [0] #7 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" [0] #8 [0] in "/home/deineruser/OpenFOAM/deineruser-2.2.2/platforms/linux64GccDPOpt/bin/XC15Heise2" [deiner:01410] *** Process received signal *** [deiner:01410] Signal: Floating point exception (8) [deiner:01410] Signal code: (-6) [deiner:01410] Failing at address: 0x3e800000582 [deiner:01410] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x2b2135d2c4a0] [deiner:01410] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0x35) [0x2b2135d2c425] [deiner:01410] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x364a0) [0x2b2135d2c4a0] [deiner:01410] [ 3] /opt/openfoam222/platforms/linux64GccDPOpt/lib/libOpenFOAM.so(_ZN4Foam8multiplyERNS_5FieldIdEERKNS_5UListIdEES6_+0xe6) [0x2b2134ef4746] [deiner:01410] [ 4] XC15Heise2(_ZN4Foam8multiplyINS_12fvPatchFieldENS_7volMeshEEEvRNS_14GeometricFieldIdT_T0_EERKS6_S9_+0xb7) [0x43b047] [deiner:01410] [ 5] XC15Heise2(_ZN4FoammlINS_12fvPatchFieldENS_7volMeshEEENS_3tmpINS_14GeometricFieldIdT_T0_EEEERKS8_SA_+0x24b) [0x45982b] [deiner:01410] [ 6] XC15Heise2() [0x422f92] [deiner:01410] [ 7] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x2b2135d1776d] [deiner:01410] [ 8] XC15Heise2() [0x424e19] [deiner:01410] *** End of error message *** -------------------------------------------------------------------------- mpirun.openmpi noticed that process rank 0 with PID 1410 on node deiner exited on signal 8 (Floating point exception). -------------------------------------------------------------------------- The fact that the FPE does not recur in restart runs at exactly the same time may simply be due to the chosen settings writeFormat ascii; writePrecision 6;, i.e. the restart is not an exact restart due to limited numerical accuracy of the restart data. Two requests to the community:
Marcus |
Floating point exception with pimpleDyMFoam | ebah6 | OpenFOAM Running, Solving & CFD | 9 | November 1, 2017 05:58 |
Inlet Velocity Profile BC - Floating Point exception during solution initialization | Janshi | STAR-CCM+ | 4 | March 14, 2012 10:21 |
simpleFoam Floating point exception error -help | sudhasran | OpenFOAM Running, Solving & CFD | 3 | March 12, 2012 16:23 |
Pipe flow in settlingFoam floating point exception | jochemvandenbosch | OpenFOAM Running, Solving & CFD | 4 | February 16, 2012 03:24 |
block-structured mesh for t-junction | Robert@cfd | ANSYS Meshing & Geometry | 20 | November 11, 2011 04:59 |
