chtMultiRegionSimpeFoam internal face problem |
November 7, 2013, 16:30 |
erik gustafsson
Rep Power: 12 |
I have a problem when im running chtMultRegionSimpleFoam, my objective is to simulate a heat exchanger and everything works fine. My problem is that i want to determine the mean velocity in different sections were my waterflow is split. Therefore i need internal face in my fluid mesh but i havent figure out how to solve this? I do my mesh in ANSA so i need to set a specific face type there. I will use the bc at the face
".*" { type calculated; } Anyone have any idea? I dont want to spilit my fluid to more than 1 region. |
November 8, 2013, 06:46 |
Vangelis Skaperdas
Rep Power: 21 |
Dear Erik,
You should set the property type to Internal in ANSA and then output the OpenFOAM mesh. ANSA will put these faces into a faceZones file inside polyMesh Hope this helps Vangelis |
November 8, 2013, 08:16 |
#3 | |
erik gustafsson
Rep Power: 12 |
Thank you for the reply, i implemented the boundary condition and it works fine except i have some new phenonemas close to the internal boundary condition as you can see in the picture. So my question now for this boundary is ".*" { type calculated; } the right approach for this BC? Thanks Erik |
November 8, 2013, 08:17 |
#4 | |
erik gustafsson
Rep Power: 12 |
November 8, 2013, 08:26 |
Vangelis Skaperdas
Rep Power: 21 |
Hi Erik,
What do we see at the image? Velocity probably, zero at the wall? I assume what you see here is a matter of visualization and not a real result. Could you display the variables in Element and not Nodal position? Vangelis |
Display Modes | |
Error message: 8 face(s) not in face lists of adjacent cells | jyoung79 | FLUENT | 0 | November 10, 2012 17:09 |
[blockMesh] Can a master patch be an internal face? | Nikunj.R | OpenFOAM Meshing & Mesh Conversion | 0 | August 3, 2012 16:27 |
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 06:50 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
[Commercial meshers] Converting meshes that includes interfaces | ham | OpenFOAM Meshing & Mesh Conversion | 29 | January 8, 2007 09:58 |
