aerogt3 |
November 11, 2013 05:59 |
Errors with thermophysicalProperties in rhoSimpleFoam
Hey all, I cannot get a single iteration to run in rhoSimpleFoam. I copied the boundary conditions and transportProperties from the tutorial below, but it still won't run!
/opt/OpenFOAM/OpenFOAM-2.2.x/tutorials/compressible/rhoSimpleFoam/angledDuctExplicitFixedCoeff
Here are the errors. Any ideas what it could be? I have tried changing BC's, changing transport models, etc. Nothing works! I am using the exact thermophysicalProperties file from the tutorial!
Reading thermophysical properties
Selecting thermodynamics package hePsiThermo<pureMixture<sutherland<hConst<perfectGas<specie>>,sensibleEnthalpy>>>
[3] #0 Foam::error::printStack(Foam::Ostream&)[9] #0 Foam::error::printStack(Foam::Ostream&)--------------------------------------------------------------------------
An MPI process has executed an operation involving a call to the
"fork()" system call to create a child process. Open MPI is currently
operating in a condition that could result in memory corruption or
other system errors; your MPI job may hang, crash, or produce silent
data corruption. The use of fork() (or system() or other calls that
create child processes) is strongly discouraged.
The process that invoked fork was:
Local host: dell-ws02.hwa.local (PID 10743)
MPI_COMM_WORLD rank: 7
If you are *absolutely sure* that your application will successfully
and correctly survive a call to fork(), you may disable this warning
by setting the mpi_warn_on_fork MCA parameter to 0.
[0] #0 Foam::error::printStack(Foam::Ostream&)[1] #0 Foam::error::printStack(Foam::Ostream&)[2] #0 Foam::error::printStack(Foam::Ostream&)[4] #0 Foam::error::printStack(Foam::Ostream&)[5] #0 Foam::error::printStack(Foam::Ostream&)[6] #0 Foam::error::printStack(Foam::Ostream&)[7] #0 Foam::error::printStack(Foam::Ostream&)[8] #0 Foam::error::printStack(Foam::Ostream&)[10] #0 Foam::error::printStack(Foam::Ostream&)[11] #0 Foam::error::printStack(Foam::Ostream&)[12] #0 Foam::error::printStack(Foam::Ostream&)[13] #0 Foam::error::printStack(Foam::Ostream&)[14] #0 Foam::error::printStack(Foam::Ostream&) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[14] #1 Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[9] #1 Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[2] #1 Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[4] #1 Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[5] #1 Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[6] #1 Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[7] #1 Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[3] #1 Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[8] #1 Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[10] #1 Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[11] #1 Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[12] #1 Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[13] #1 Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[1] #1 Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[0] #1 Foam::sigFpe::sigHandler(int) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[2] #2
[5] #2
in "/opt/OpenFOAM/OpenFOAM-2.2.x/platform in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" in "/opt/OpenFOAM/OpenFOAM-2.2.x/platfos/linux64GccDPOpt/lib/libOpenFOAM.so"
[7] #2 rms/linux64GccDPOpt/lib/libOpenFOAM[4] #2
.so"
[6] #2
[3] #2
[8] #2
[10] #2
in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM. in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libOpenFOAM.so"
[12] #2
[13] #2
[9] #2
[14] #2
[1] #2
so"
[0] #2
[2] at sigaction.c:0
[2] #3 Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate()[6] at sigaction.c:0
[6] #3 [4] at sigaction.c:0
[7] at sigaction.c:0
[7] #Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate()[5] at sigaction.c:0
[5] #3 Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate()3 Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate()[4] #3 Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate()[3] at sigaction.c:0
[3] #3 Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate()[1] at sigaction.c:0
[1] #3 Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate()[8] at sigaction.c:0
[8] #3 [10] at sigaction.c:0
[10] #3 [14] at sigaction.c:0
[14] #3 [12] at sigaction.c:0
[12] #3 [13] at sigaction.c:0
[13] #3 Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate()[0] at sigaction.c:0
[0] #3 Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate()Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate()Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate()Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate()Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate()[9] at sigaction.c:0
[9] #3 [11] at sigaction.c:0
[11] #3 Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate()Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::calculate() in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so"
[2] #4 Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::hePsiThermo(Foam::fvMesh const&, Foam::word const&) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so"
[6] #4 Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::hePsiThermo(Foam::fvMesh const&, Foam::word const&) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so"
[4] #4 Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::hePsiThermo(Foam::fvMesh const&, Foam::word const&) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so"
in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDP[7] #4 Opt/lib/libfluidThermophysicalModels.so"
[5] #4 Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::hePsiThermo(Foam::fvMesh const&, Foam::word const&)Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::hePsiThermo(Foam::fvMesh const&, Foam::word const&) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so"
[1] #4 Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::hePsiThermo(Foam::fvMesh const&, Foam::word const&) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so"
[3] #4 Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::hePsiThermo(Foam::fvMesh const&, Foam::word const&) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so"
[0] #4 Foam::hePsiThermo<Foam::psiThermo, Foam::pureMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::hConstThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::hePsiThermo(Foam::fvMesh const&, Foam::word const&) in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/lin in "/opt/OpenFOAM/OpenFOAM-2.2.x/platf in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/li in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccD in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/ in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/ in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libfluidTh in "/opt/OpenFOAM/OpenFOAM-2.2.x/platforms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so"
[12] #4 ux64GccDPOpt/lib/libfluidThermophysicalModels.so"
[8] #4 orms/linux64GccDPOpt/lib/libfluidThermophysicalModels.so"
[14] #4 nux64GccDPOpt/lib/libfluidThermophysicalModels.so"
[10] #4 POpt/lib/libfluidThermophysicalModels.so"
[9] #4 libfluidThermophysicalModels.so"
[2] #5 libfluidThermophysicalModels.so"
[13] #4 ermophysicalModels.so"
My initial conditions are:
epsilon: 6.9 for epsilon on all walls and freestream, compressible::epsilonWallFunction, fixed value inlet, zero grad outlet
k: same as above, but 0.015 as the value and compressible::kqRWallFunction
T: fixedValue at inlet, zeroGrad everywhere else.
Pressure:
dimensions [ 1 -1 -2 0 0 0 0 ];
internalField uniform 101325;
boundaryField
velocityinlet
type totalPressure;
gamma 1.4;
p0 uniform 102856.25;
pressureoutlet
type fixedValue;
value $internalField;
Velocity:
dimensions [ 0 1 -1 0 0 0 0 ];
internalField uniform ( 0 0 0 );
boundaryField
velocityinlet
type pressureInletVelocity;
value uniform ( 0 0 0 );
pressureoutlet
type zeroGradient;
