ERROR : Floating point exception (core dumped) |
November 14, 2013, 02:27 |
Rep Power: 12 |
Hi
I am simulating a overflow valve with simple foam. Velocity of fluid is 0.27 m/s Dynamic Viscosity = 8.26 X 10^-6 Kg/m.s Density = 830 Kg / m3 Radius of the inlet = 6.9 mm I am getting the error which is attached and also looked in to many discussions on this topic but not able to fix this issue.. Please help me |
November 14, 2013, 05:33 |
Martin Beeger
Rep Power: 12 |
Your viscosity maybe too small. Try a bigger value and see if this fixes your error.
This shown error is a preconditioner failure, if increasing viscosity does not help try tuning preconditioner parameters. |
November 14, 2013, 06:00 |
simpleFOAM SOLVER
Rep Power: 12 |
[FoamFile
{ version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver PCG; preconditioner DIC; tolerance 1e-06; relTol 0.01; } U { solver PBiCG; preconditioner DILU; tolerance 1e-05; relTol 0.1; } k { solver PBiCG; preconditioner DILU; tolerance 1e-05; relTol 0.1; } epsilon { solver PBiCG; preconditioner DILU; tolerance 1e-05; relTol 0.1; } R { solver PBiCG; preconditioner DILU; tolerance 1e-05; relTol 0.1; } nuTilda { solver PBiCG; preconditioner DILU; tolerance 1e-05; relTol 0.1; } } SIMPLE { nNonOrthogonalCorrectors 2; pRefCell 101; pRefCell 58; pRefCell 767; pRefCell 527; pRefValue 0; residualControl { p 1e-2; U 1e-3; "(k|epsilon|omega)" 1e-3; } } relaxationFactors { fields { p 0.3; } equations { U 0.7; k 0.7; epsilon 0.7; R 0.7; nuTilda 0.7; } } // ************************************************** *********************** //] THis is the solver file... Please check let me know anything need to be changed ? |
November 14, 2013, 06:40 |
Martin Beeger
Rep Power: 12 |
Try setting the dynamic viscosity to a bigger value (like 8e-3 instead of 8e-6). I don't actually know which changes you have to make to get you preconditioner able to handle these viscosities.
November 14, 2013, 07:03 |
Rep Power: 12 |
I should not change dynamic viscosity as these are defined values for my case ... |
Display Modes | |
Ercoftac centrifugal pump case study bug, Openfoam 1.6-ext (Floating point exception) | ArianeJasmin | OpenFOAM Programming & Development | 1 | April 4, 2012 15:11 |
Exception en point flottant | thomasse | OpenFOAM | 3 | August 9, 2011 01:50 |
Finished simulation doesn't start: floating point exception [Divide by zero] | MaxCFD | STAR-CCM+ | 3 | June 26, 2011 11:31 |
Flouting point exception twoPhaseEulerFoam - I set delta t | cristina87 | OpenFOAM | 1 | May 26, 2011 16:35 |
CFX4.3 -build analysis form | Chie Min | CFX | 5 | July 13, 2001 00:19 |
