June 10, 2013, 12:46 |
custom inlet problem with parallel runs
Hansjoerg Seybold
Rep Power: 17 |
I created custom velocity inlets for a) linear shear flow b) logarithmic velocity profile to use them with pisoFoam. For testing I run the following commands: 1) ~>decomposePar 2) ~>mpirun -np 4 pisoFoam -parallel -case . 3) ~>pisoFoam -case . In the case of the linear inlet (a): 1-3 run without error In the case of the logarithmic inlet (b): only (1) and (3) run running pisoFoam in parallel however fails with the error message below. The corresponding section in the velocity 0/U: ... inlet { type logVelocity; n (1 0 0); y (0 0 1); uStar 1.0; z0 0.1; kappa 0.41; //value uniform (0 0 0); // for paraview } I dont know where to search for the error, as my configs/custom libs run fine in the serial case. When checking the processor0 - processor3 directories I found that the kappa entry was missing in the U dictionary. After adding the entry manually I succeeded running the case Hope somebody has an idea why decomposePar omits the entry Thanks a lot hj ----------------------------------------------------------------------- ... [0] --> FOAM FATAL IO ERROR: [0] keyword kappa is undefined in dictionary "/net/segovia/home/hansjoerg/Projects/Particles_in_Flow/CFDEM/hansjoerg-PUBLIC-2.1.x/pisoShearFlowCFDEM1/CFD/processor0/0/U::boundaryField::inlet" [0] [0] file: /net/segovia/home/hansjoerg/Projects/Particles_in_Flow/CFDEM/hansjoerg-PUBLIC-2.1.x/pisoShearFlowCFDEM1/CFD/processor0/0/U::boundaryField::inlet from line 36 to line 41. [0] [0] From function dictionary::lookupEntry(const word&, bool, bool) const [0] in file db/dictionary/dictionary.C at line 400. [0] FOAM parallel run exiting .... ----------------------------------------------------------------------- Last edited by hansjoerg; June 10, 2013 at 13:51. |
June 10, 2013, 13:58 |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Greetings Hansjoerg,
Not much information to work with... this is one of those "which I had a crystal ball" kind of moments... Nonetheless, I do believe I know what the problem is, because I fixed one of these problems not too long ago. Check the source code for "libMyPolynomVelocity" from the following two posts:
Best regards, Bruno
June 10, 2013, 14:40 |
Hansjoerg Seybold
Rep Power: 17 |
Thanks a lot for he reply. Problem solved. I went through your suggested posts and I think that i found the problem: At the end of the library definition in the function void logVelocityFvPatchVectorField::write(Ostream& os) const the entry for "kappa": os.writeKeyword("kappa")<< kappa_ << token::END_STATEMENT << nl; was missing. This seems to be ok in serial jobs but crucial in parallel calculations. Cheers hj Last edited by hansjoerg; June 10, 2013 at 18:28. |
November 15, 2013, 10:05 |
Rep Power: 14 |
How did you read the entry kappa outside the logVelocityFvPatchVectorField?
Problem with assigned inlet velocity profile as a boundary condition | Ozgur_ | FLUENT | 5 | August 25, 2015 04:58 |
Flux Problem at Inlet | piyushsharma0487 | Fluent UDF and Scheme Programming | 9 | April 19, 2012 02:57 |
How to assign the inlet B.C using a bunch of data set for an unsteady problem? | ali8500 | CFX | 3 | March 28, 2012 18:41 |
Parallel runs with sonicDyMFoam crashes (works fine with sonicFoam) | jnilsson | OpenFOAM Running, Solving & CFD | 0 | March 9, 2012 06:45 |
parallel mode - small problem? | co2 | FLUENT | 2 | June 1, 2004 23:47 |
