Home > Forums > OpenFOAM Running, Solving & CFD
decomposePar looses patchField entries
Old   November 15, 2013, 19:02
Default decomposePar looses patchField entries
Marcus Letzel
letzel is on a distinguished road
Dear Foamers,
my following workflow does not work, I hope it just requires a simple correction:
blockMesh > blockMesh.log 2>&1
decomposePar -force > decomposePar1.log 2>&1
surfaceFeatureExtract > surfaceFeatureExtract.log 2>&1
foamJob -parallel snappyHexMesh
foamJob -parallel checkMesh -latestTime
cp -pv 0/* 0.2 > cp.log 2>&1
setFields > setFields.log 2>&1
decomposePar -fields -latestTime -constant > decomposePar2.log 2>&1
foamJob -parallel pimpleFoam
snappy performs two steps, dt is 0.1 s, hence I copy the initial fields from 0 to latestTime=0.2.
pimpleFoam complains:
Create mesh for time = 0.2
Reading field p
[0]
[0]
[0] --> FOAM FATAL IO ERROR:
[0] Cannot find patchField entry for alexanderplatz_alexanderplatz
[0]
[0] file: /home/meineruser/OpenFOAM/meineruser-2.2.2/run/[...]/processor0/0.2/p.boundaryField from line 26 to line 41.
[0]
[0]     From function GeometricField<Type, PatchField, GeoMesh>::GeometricBoundaryField::readField(const DimensionedField<Type, GeoMesh>&, const dictionary&)
[0]     in file /opt/openfoam222/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 206.
[0]
FOAM parallel run exiting
p in processor0/0.2 simply reads
|  \\    /   O peration     | Version:  2.2.2                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    location    "0.2";
    object      p;
dimensions      [0 2 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    defaultName
        type            zeroGradient;
    procBoundary0to1
        type            processor;
        value           uniform 0;
    procBoundary0to2
        type            processor;
        value           uniform 0;
    procBoundary0to3
        type            processor;
        value           uniform 0;
But p in the 0.2 subdirectory of the case directory still has all the patches specified:
|  \\    /   O peration     | Version:  2.1.1                                 |
FoamFile
    version     2.0;
    format      ascii;
    location    "0";
    object      p;
libs (
         "libgroovyBC.so"
boundaryField
    alexanderplatz_patch_ausgang_db
        type            groovyBC;
        value           uniform 0;
        valueExpression "0";
        gradientExpression "0";
        fractionExpression "inVel<0 ? 1 : 0";
        timelines (
            name        inVel;
            outOfBounds clamp;
            fileName    "$FOAM_CASE/input_data/patch_ausgang_db.txt";
    "(alexanderplatz_patch_ausgang_a.*|alexanderplatz_patch_ausgang_b.*|alexanderplatz_patch_ausgang_l.*|alexanderplatz_patch_ausgang_u.*|alexanderplatz_patch_t.*)"
        type            fixedValue;
    value        uniform 0;
    "(alexanderplatz_alexanderplatz|treppen_treppen|saeulen_saeulen|defaultName)"
        type            zeroGradient;
Looking forward to hear any suggestions to revise my workflow.
Cheers,
Marcus
letzel is offline   Reply With Quote
Old   November 18, 2013, 05:06
Marcus Letzel
Forgot to add that a slightly modified workflow including a reconstructParMesh step works as follows:
reconstructParMesh -latestTime -mergeTol 1e-06
decomposePar -latestTime -force > decomposePar2.log 2>&1
Is it possible to avoid this extra step?
Thread Tools
Trackbacks are On
adding compressible option to ptot immortality OpenFOAM Programming & Development 13 June 15, 2015 15:00
Help with if statement CHARLES OpenFOAM Programming & Development 15 September 18, 2013 18:29
Elementwise multiplication operator johndeas OpenFOAM Running, Solving & CFD 2 May 14, 2012 09:45
decomposePar gives errors of_user_ OpenFOAM 1 July 4, 2011 05:27
A stupid question luckyluke OpenFOAM Running, Solving & CFD 14 August 13, 2007 04:25
