-   -   A problem about parallel computing (http://www.cfd-online.com/Forums/openfoam-solving/126488-problem-about-parallel-computing.html)
babala November 19, 2013 05:33
I am running a test on a Redhat server.I plan to run the test with two nodes(every node has 8 CPUs). We can name the two nodes as node1 and node2.
I use the commond as userguide:
mpirun -hostfile machine -np 16 rhoCentralFoam -parallel
The file of machine is like this:
node1
node2
However, the terminal gives me a error information follows:
Open RTE detected a parse error in the hostfile:
machine
It occured on line number 3 on token 1.
[c2-8:27938] [[27546,0],0] ORTE_ERROR_LOG: Error in file base/ras_base_allocate.c at line 222
[c2-8:27938] [[27546,0],0] ORTE_ERROR_LOG: Error in file base/plm_base_launch_support.c at line 99
[c2-8:27938] [[27546,0],0] ORTE_ERROR_LOG: Error in file plm_rsh_module.c at line 1173
Then, I just use one node, And I modify the file of machine as this:
node1
And input the commond
mpirun -hostfile machine -np 8 rhoCentralFoam -parallel
the solver can work successifully.
And the other node is OK,too.I don't know how to solve this problem.
Any answers is appreciated.
best regards
Zhiyuan Li
wyldckat November 26, 2013 18:23
Greetings Zhiyuan Li and welcome to the forum!
Quick answer - follow these instructions: 7. How do I run a simple SPMD MPI job?
Long answer - check this blog post with a lot of links that can help with several topics regarding running in parallel: Notes about running OpenFOAM in parallel
Best regards,
Bruno
babala November 27, 2013 00:31
Best regards,
Bruno
hello, Bruno.
Thank you for your replies.
I have solved the problems. I created the file of machine.txt in Windows system and editted it in Windows system,too.And, Linux system can't identify contents of the file.Then I editted the file by vim and the solver can run in parallel perfectly.
The mistake is so stupid.Hope somebody else won't make the same mistake.
Best regards
Zhiyuan
