Home > Forums > OpenFOAM Running, Solving & CFD
::: Constant mesh motion ?
Old   November 21, 2013, 06:41
Default ::: Constant mesh motion ?
cuba is on a distinguished road
Hi everyone,
I have a mesh motion problem in my code. Simply, I want to move all points in my domain (except points at outlet) with the same velocity in x-direction defined at inlet. I want to preserve the initial cell sizes (except the cells neighbouring outlet patch) that I give at start.
Is it possible to achieve this with laplaceFaceDecomposition with just adjusting the diffusivity function? as the current code is based on this for now and it also works in parallel.
Any comments are very much appreciated.
Best,
A very simple drawing would be as given below
o: outlet vertice
i: inlet vertice
|: internal vertices
o______|__|__|__|__i t=0
o_____|__|__|__|__i t=1
o___|__|__|__|__i t=2
o____|__|__|__|__i t=3
cuba is offline   Reply With Quote
Old   November 26, 2013, 11:19
any help regarding the above question would be very much appreciated.
let me also put the above given question in the following way that
how can I map the "motionU" computed for the inlet to the rest of the domain except the outlet, so that all the points in the domain move with the same velocity except again the outlet? any examples/ideas? ...i.e. just replacing the "motionEqn" given in "laplaceFaceDecomposition" solver with something that would the trick or anything else?
in the meantime what is the meaning of "tetPointVectorField" ?
for example I have a domain 12x10x10=1200 cells (x-y-z, z is vertical) overall, 100 cells at the inlet. Then I would have have (10+1)^2=121 points at the inlet patch and (12+1)*(10+1)^2=1573 points in total, but when I check motionU file, in the internal field I have 6713 data points and at the inlet 216 data points? what do we mean by tetPointVectorField so that I have more data points than the actual total number of points?
Thanks
Best
Old   November 26, 2013, 12:11
Jens Höpken
jhoepken is on a distinguished road
Send a message via Skype™ to jhoepken
If you would like to move all points similarly, have a look at solidBodyMotionFvMesh and the corresponding solidBodyMotionFunctions.
cheers,
Jens
jhoepken is offline   Reply With Quote
Thread Tools
Trackbacks are On
Star CCM Overset Mesh Error (Rotating Turbine) thezack CD-adapco 4 April 26, 2016 02:03
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 8 December 3, 2013 17:51
Dynamic moving mesh Pei-Ying Hsieh (Hsieh) OpenFOAM Running, Solving & CFD 64 June 7, 2012 10:04
Prescribed mesh motion does not correspond to actual motion rbarrett CFX 8 June 30, 2011 13:22
