[waves2Foam] Questions about relaxation zones and dynamic pressure pd |
July 29, 2015, 22:41 |
ALLEN
Rep Power: 11 |
Hello,Nielson,
I have recently used your waves2Foam in foam-extend-3.1 for my study on runup, I have 2 questions that have haunted me for a long time: 1. first, about the inlet relaxation zone, here is my setup: Code:
seaLevel 0.45; wind (0 0 0); relaxationNames (inlet outlet); initializationName outlet; inletCoeffs { waveType stokesFirst; Tsoft 0.6; depth 0.45; period 0.6; phi 0.000000; direction (1.0 0.0 0.0); height 0.04; relaxationZone { relaxationScheme Spatial; relaxationShape Rectangular; beachType Empty; relaxType INLET; startX (0 -1 0); endX (1 1 0); orientation (1.0 0.0 0.0); } }; outletCoeffs { waveType potentialCurrent; U (0 0 0); Tsoft 0.6; relaxationZone { relaxationScheme Spatial; relaxationShape Rectangular; beachType Empty; relaxType OUTLET; startX (3 -1 0); endX (4 1 0); orientation (1.0 0.0 0.0); } }; According to your paper, an inlet relaxationZone setup behind the wake generation boundary is used to consider the reflection from the body of the tank, like cylinders or floating bodies in the middle of the tank, is that right? 2. The second question is about the dynamic pressure pd. According to the code, pd is initialised by "setWaveField" utility, and I searched the code, find: Code:
if (lc.ccNeg().size() >= 4) { UTarget = waveProps_->U( lc.centreNeg(), U_.db().time().value() ); pTarget = waveProps_->p( lc.centreNeg(), U_.db().time().value() ); alphaTarget = lc.magNeg()/V[celli]; } U_[celli] = UTarget; alpha_[celli] = alphaTarget; p_[celli] = pTarget; so according to the above wavesproperties.input, I start to run the case, but the pd result is high everywhere after about 80 time steps. Actually, pd is fefined as (p-rgh), it shouldn't have so high value, right? I guess there might be some misunderstanding or wrong setup in my case, solution set up is: Code:
solvers { pdcorr { solver PCG; preconditioner { preconditioner GAMG; tolerance 1e-05; relTol 0; smoother DICGaussSeidel; nPreSweeps 0; nPostSweeps 2; nBottomSweeps 2; cacheAgglomeration false; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; } tolerance 1e-05; relTol 0; maxIter 100; }; pd { solver GAMG; tolerance 1e-08; relTol 0.01; smoother DIC; nPreSweeps 0; nPostSweeps 2; nFinestSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; }; pdFinal { solver PCG; preconditioner { preconditioner GAMG; tolerance 2e-09; relTol 0; nVcycles 2; smoother DICGaussSeidel; nPreSweeps 2; nPostSweeps 2; nFinestSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 10; agglomerator faceAreaPair; mergeLevels 1; } tolerance 2e-09; relTol 0; maxIter 20; }; U { solver PBiCG; preconditioner DILU; tolerance 1e-06; relTol 0; minIter 1; }; UFinal { solver PBiCG; preconditioner DILU; tolerance 1e-06; relTol 0; minIter 1; }; gamma { solver PBiCG; preconditioner DILU; tolerance 1e-06; relTol 0; minIter 1; }; } PISO { cAlpha 1; nCorrectors 2; nNonOrthogonalCorrectors 1; nOuterCorrectors 20; ddtPhiCorr true; pdRefCell 0; pdRefValue 0; } PIMPLE { pRefCell 0; pRefValue 0; pdRefCell 0; pdRefValue 0; momentumPredictor yes; nOuterCorrectors 1; nCorrectorsP 1; nCorrectorsU 1; nNonOrthogonalCorrectors 3; nAlphaCorr 1; nAlphaSubCycles 1; } relaxationFactors { fields { pd 0.3; } equations { U 0.7; k 0.7; epsilon 0.7; R 0.7; nuTilda 0.7; } } Thank you, the attachment is on the pd field for my case, time step=0.001s. This case is just a test case, not physical consideration at all. pd-different-time-step.tar.gz |
July 31, 2015, 05:49 |
Niels Gjoel Jacobsen
Rep Power: 37 |
Hallo Allen,
@1: I do not fully understand your concern, but yes, the relaxation zones are merely a matter of avoiding (re-)reflection from the boundaries. An additional benefit is that it allows for the simulation of thousands of waves without an accumulation of water in the computational domain due to the Stokes drift, see our recent paper Jacobsen et al. (2015) in Coastal Engineering. @2: It is caused by the fact that your sea level is not defined at 0.0. Kind regards, Niels
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request. |
August 1, 2015, 23:19 |
#3 | |
ALLEN
Rep Power: 11 |
Thanks for your reply, Nielson, @1: Okay, I will look into the code to find the difference when you realise the inlet and outlet relaxzation zone. @2: so it won't affect the computation if I set the seaLevel not to be 0.0? or: do I have to see the seaLevel to be 0.0 to have a "correct" result ? might be stupid for the above questions, but I just want to make sure. Thanks and have a nice weekend! from Allen |
August 3, 2015, 02:26 |
Rep Power: 37 |
Good morning Allen,
If you treat your pressure boundaries correctly it should, conceptually work. An old version (OF1.7) worked with total pressure and some people observed convergence issues, so a large value of the sea level might have the same effect, but I have never testeed it. Kind regards Niels
CFX Solver stopped with error when requested for backup during solver running | Mfaizan | CFX | 40 | May 13, 2016 06:50 |
Dynamic mesh questions plus what the frack is up with named selections | Maurosso | FLUENT | 2 | March 25, 2013 04:59 |
dynamic zones in rigidbody motion | aamer | Main CFD Forum | 0 | April 3, 2011 04:02 |
Defining dynamic zones for Define CG motion | aamer | Main CFD Forum | 0 | March 21, 2011 03:51 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
