Problem in running foam-extend-3.0/tutorials/incompressible/simpleSRFFoam |
February 5, 2014, 05:13 |
Rep Power: 12 |
Hi
I have installed foam-extend-3.0 in home/openFOAM/foam-extend-3.0/ And also run the case icoFOAM by coping tutorial to home/OpenFOAM/run/. But when i tried to run simpleSRFFoam and icoDyMFoam then it didn't happen . Please take a look in to scream shots which depicts the locations of foam-extent-3.0 and tutorials . And also a screan shot depicting the out put of the run . Please suggest me how can i run simpleSRFFoam and icoDyMFoam ? |
February 5, 2014, 09:47 |
Nima Samkhaniani
Rep Power: 24 |
your screen shots don't have any useful data , try to run each commands in Allrun file in simpleSRFFoam serially in terminal to find out which command does not work.
My Personal Website (http://nimasamkhaniani.ir/) Telegram channel (https://t.me/cfd_foam) |
February 5, 2014, 16:24 |
Wouter van der Meer
Rep Power: 17 |
hello sam.ho,
I 'm aabsolutely no expert, but I recall a thread were it is mentioned that foam-extend-3.0 needs to be installed in ~/foam not in ~/openFOAM unless you change a lot of things in the setting files. hope this helps Wouter |
Display Modes | |
[Other] mesh airfoil NACA0012 | anand_30 | OpenFOAM Meshing & Mesh Conversion | 13 | March 7, 2022 18:22 |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 15:07 |
[blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 06:42 |
gmsh2ToFoam | sarajags_89 | OpenFOAM | 0 | November 24, 2009 23:50 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 15:00 |
