December 17, 2013, 02:37 |
Boundary conditions conjugate heat transfer
ande
Rep Power: 12 |
I want to simulate the heat transfer between a hot solid sphere and an airflow in a zylinder. I want to simulate the case with chtMultiRegionSimpleFoam. For the beginning is set the turbulence model to laminar.
After a few iterations, I get the following error: --> FOAM FATAL ERROR: Continuity error cannot be removed by adjusting the outflow. Please check the velocity boundary conditions and/or run potentialFoam to initialise the outflow. Total flux : 0.003735908 Specified mass inflow : 0.05406901 Specified mass outflow : 0 Adjustable mass outflow : 0 From function adjustPhi(surfaceScalarField& phi, const volVectorField& U,const volScalarField& p in file cfdTools/general/adjustPhi/adjustPhi.C at line 118. FOAM exiting Iam not sure how I should set the boundary conditions. Can anyone help me with this? The case files can be downloaded. I had to delete the mesh information because it was to big. |
December 17, 2013, 12:27 |
#2 | |
Jace
Rep Power: 15 |
1. in your sphere/T, you have symmetry plane all over the places...and I think you meant to put zeroGradient? You should double check that. 2. for fluid/U, at the outlet, try putting it as zeroGradient instead of the inletOutlet. 3. I didn't check other fields in the 0 directory, but you should go through them and get rid of all occurrence of "symmetryPlane" for BCs that are actually not a symmetry plane.... Try these and let's see what happens. Good luck! |
December 18, 2013, 03:38 |
ande
Rep Power: 12 |
thank you very much for your answer.
I put the outlet boundary in fluid/U as zeroGradient. Seems to work quite well. I used snappyHexMesh to create the mesh. Therefore I many boundaries with zero faces. I set these boundaries as symmetryPlane because I saw the same in the tutorial iglooWithFridges. Should I set these boundaries to "empty"? |
December 18, 2013, 08:56 |
ande
Rep Power: 12 |
I have another question concerning the boundary conditions.
At the beginning the sphere should have a temperature e.g. of 400K. It should heat up the airflow around it, which has e.g. 300K at the inlet. But the sphere must have the ability to cool down. I want to simulate the case with chtMultiRegionSimpleFoam. Which boundary conditions can I use to get this? At the moment I have the following boundary conditions between the sphere and the fluid: in 0/fluid/T: fluidToSphere { type compressible::turbulentTemperatureCoupledBaffleMix ed; value uniform 300; neighbourFieldName T; kappa fluidThermo; kappaName none; } in 0/sphere/T: sphereToFluid { type compressible::turbulentTemperatureCoupledBaffleMix ed; value uniform 400; neighbourFieldName T; kappa solidThermo; kappaName none; } Does anyone have a suggestion? |
conjugate heat transfer boundary condition | Souviktor | FLUENT | 6 | April 6, 2014 17:34 |
Simplest boundary conditions for multi-region heat transfer simulation | leroyv | OpenFOAM Running, Solving & CFD | 2 | December 9, 2013 05:37 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
Defining Boundary conditions for heat transfer | sujay | CFX | 7 | May 14, 2010 08:00 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
