Home > Forums > OpenFOAM Running, Solving & CFD
problem with results; viscous layer formed on a flat plate
Old   December 27, 2013, 12:26
Default problem with results; viscous layer formed on a flat plate
coroi is on a distinguished road
Hello everyone!
I have a problem when i'm simulating an 2D uncompressible flow of the air above a flat plate.I need to obtain a u+=f(y+) law and compare it to the theory. The result that i have obtained (have a look at the image) does not look like the theoretical one as you can see on the image. The blue plot correspond to the result that I have obtained.
I used simpleFoam solver (openFOam1.7.1). The numerical schemes used are listed in the image attached to the post.
I think that the problem may be in the not sufficiently refined mesh close to the plate, or in the numerical schemes used.
If someone have an idea where the problem could be thank you for your indications .
coroi is offline   Reply With Quote
Thread Tools
Trackbacks are On
Flow over a flat plate as an immersed solid hamed.majeed CFX 4 September 8, 2016 14:40
rhoCentralFoam flat plate boundary layer issues laurensvd OpenFOAM Running, Solving & CFD 6 September 13, 2013 03:10
Problem in getting mesh independent soluiton for flow over flat plate BHE FLUENT 21 January 31, 2013 00:03
problem in turbulent flow over flat plate with stagnation point mb.pejvak Main CFD Forum 0 September 12, 2012 21:25
Turbulent Bounadry layer on a ZPG flat plate Eldude Main CFD Forum 2 October 16, 2008 02:44
