Oscillating behaviour when mesh gets too small
Old   January 9, 2014, 05:04
Default Oscillating behaviour when mesh gets too small
James B
james91 is on a distinguished road
Dear Foamers
I am simulating detonations with a 2nd order approximate Riemann Solver. The results are smooth when I have a relative coarse mesh size of 1 mm but when I refine my mesh the solver starts to oscillate in every variable (see figure), would you have any idea on how to solve this problem or where it comes from ? (Maybe adapting the FVScheme and add more dissipation)?
The mesh is a 1D shocktube (1 cell with upper and lower BC symmetry conditions imposed)
Thank you very much!!
Here is the FvScheme from DDTFoam
ddtSchemes
    default         Euler;
gradSchemes
    default         Gauss linear;
    grad(scalarSlope)    cellMDLimited Gauss linear 1;
    grad(USlope)    cellMDLimited Gauss linear 1;
divSchemes
    default         none;
    div(tauShear)            Gauss linear;
    div(tauMC)                Gauss linear;
    div((tauShear&U))        Gauss linear;
    div((p*U))            Gauss linear;
    div((U+((sL*Xi)*-grad(c)))) Gauss linear;
    div((sL*grad(b)))         Gauss linear;
    div(U)                 Gauss linear;
    div((sL*-grad(c)))         Gauss linear;
    div(phiSt,c)        Gauss vanLeer01;
    div(phiXi,Xi)    Gauss vanLeer;
    div(phi,k)              Gauss upwind;
    div(phi,epsilon)     Gauss upwind;
    div(phi,omega)     Gauss upwind;
laplacianSchemes
    default         Gauss linear corrected;
interpolationSchemes
    default none;
    interpolate(tauMC) Gamma phi 1.0;
    interpolate(mu) Gamma phi 1.0;
    interpolate(muEff) Gamma phi 1.0;
    reconstruct(rho) limitedLinear 1.0;
    reconstruct(U)   limitedLinearV 1.0;
    reconstruct(T)   limitedLinear 1.0;
    interpolate(rho) linear;         // for CFL
    reconstruct(cSound) linear;     // for CFL
    interpolate(p) linear;           // for MinMax scheme
    interpolate(Teff) linear;         // for MinMax scheme
    interpolate(tau) linear;          // for MinMax scheme
    interpolate(-grad(c)) linear;
    interpolate(grad((1-c))) linear;
    interpolate((((p*psiu)*sL)*Xi)) linear;
    interpolate((sL*((1|Xi)-Xi))) linear;
    interpolate(((rhoUnburned*sL)*Xi)) linear;
    interpolate((laplacian(interpolate(alphaEff),c)|mag(-grad(c)))) linear;
snGradSchemes
    default         corrected;
james91 is offline   Reply With Quote
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 11:45
Gambit: mesh size to small??? Ralf Schmidt FLUENT 1 January 28, 2006 01:26
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
