November 14, 2017, 08:14 |
Cp values larger than 1
stergiani
Rep Power: 9 |
Hei,
I'm running simpleFoam for air flow around buildings and I want to calculate the Cp values on the facades. The weird thing is that I get values way greater than 1, around 1.2, which seems wrong for my incompressible flow. The inlet pressure is set at 0, so I guess my reference pressure is equal to 0. I checked air viscosity and velocity profiles, and everything looks normal. Any ideas on what I have missed? Thanks Stergiani |
November 15, 2017, 02:58 |
matej forman
Rep Power: 17 |
Well in incompressible flow, your pressure is not in Pascals but in Pa/rho .I do not recall the c_p expression very well but can the density influence your results?
matej |
November 15, 2017, 04:08 |
stergiani
Rep Power: 9 |
Hei, Matej.
Thank you for your reply. Yes, I have checked it and still get extreme values, around 1.5 I calculate the Cp by the following equation Cp=(p-p0)/(1/2*ρ*Uref^2). Since my pressure in inlet and outlet is set to 0, I guess that p0=0. Could it be that my domain is small, and although it looks like the solution is converged, I get wrong results? Thanks Stergiani |
November 15, 2017, 04:41 |
matej forman
Rep Power: 17 |
Hmmm....
I guess the pressure difference is multiplied by density in your incompressible place. As the c_p looking at the coefficient takes only the static pressure difference from the simulation, if the numbers are wrong, it must the pressure. To get a good pressure distribution on the surface you need to make sure your mesh is correct. For your RANS simulation you need to have a good prismatic layer with a proper y+ values. And good convergence. |
November 15, 2017, 07:22 |
stergiani
Rep Power: 9 |
Thanks, Matej!
I improved my mesh and everything looks better. The convergence is good, but my yplus is around 200. And I'm a bit confused about yplus, cause some take it very small, but others consider even up to 300. Any insight? Sorry, for the many questions, but it's my first time working on CFD Stergiani |
November 15, 2017, 08:04 |
matej forman
Rep Power: 17 |
Now you have landed on a very special ground. BL modelling is still a question in CFD. OpenFOAM is using highRe wall functions where your y+ should be around 30-300. Unless you are resolving the BL with a number of cells
Please have a look here: https://www.openfoam.com/documentati...urbulence.html and read any book on CFD, e.g. https://www.amazon.com/Introduction-...lalasekera+cfd or similar. |
November 15, 2017, 08:47 |
stergiani
Rep Power: 9 |
I have already got the book you suggested, so I'd better start studying
Thank you for all the help! Stergiani |
pressure distribution |
using chemkin | JMDag2004 | OpenFOAM Pre-Processing | 2 | March 8, 2016 22:38 |
cyclic BC - modify boundary face values | marluc | OpenFOAM Programming & Development | 0 | May 4, 2015 16:50 |
Velocity values are normal but pressure values are too big | rv82 | OpenFOAM Running, Solving & CFD | 4 | April 13, 2015 03:59 |
Setting patch field values equal to internal field values | leroyv | OpenFOAM Programming & Development | 1 | October 21, 2014 15:49 |
strange node values @ solid/fluid interface - help | JB | FLUENT | 2 | November 1, 2008 12:04 |
