Home > Forums > OpenFOAM Running, Solving & CFD
InterPhaseChangeFoam: trying to simulate cavitation phenomena inside of nozzle
Like Tree1Likes
  • 1 Post By shipman
Old   January 20, 2014, 02:53
Default InterPhaseChangeFoam: trying to simulate cavitation phenomena inside of nozzle
Baris (Heewa)
shipman is on a distinguished road
Dear Foam Users,
I am trying to simulate cavitation phenomena inside of nozzle and using interphasechangefoam. As you know that there are 3 transport models (Merkle, Kunz and Sauer) I have tried all of these 3 models with kwSST turbulence model however i have problems with the obtaining of cavitation region as follows;
1. If i set the initial cond. according to Velocity as follows:
==> 0/U
internalField   uniform (0 3.104 0);
boundaryField
    inlet
        type            fixedValue;
        value           $internalField;
      outlet
        type            pressureInletOutletVelocity;
        phi             phi;
    wall
        type            fixedValue;
        value            uniform (0 0 0);
==>0/P
internalField   uniform 1e5;
boundaryField
   inlet
         type           zeroGradient;
    outlet
        type            fixedValue;
    wall
        type           zeroGradient;
cavitation starts to form until to some level, however after that it disappears although flow rate is increasing. I didnt understand why this happens? (as seen in the attached fig.)
2.if i set the initial cond. according to pressure as follows:
==>0/P
boundaryField
    inlet
        type            fixedValue;
        value           uniform 2.8e5;
    outlet
        type            fixedValue;
   wall
        type           zeroGradient;
==>0/U
internalField   uniform (0 0 0);
boundaryField
    inlet
        type            zeroGradient;
    outlet
        type            inletOutlet;
        inletValue       uniform (0 0 0);
    wall
        type            fixedValue;
in this case no cavitation form obtained. Therefore i am confused. Could someone advice me something or give some insight what kind of reasons can result in these results? I increased mesh number, changed mass transport model( means i tried 3 of models) still gives same results...
In addition; For interphasechange solver (or more generally if we try simulation multiphase with mass transition which initial condition setting is more logical; pressure or velocity based?
Thanks in advance...
shipman is offline   Reply With Quote
Old   January 20, 2014, 02:55
Baris (Heewa)
Sorry I forgat to say that initial velocity and pressure values are taken from the experiment...
Old   April 23, 2015, 08:46
Alexander Bartel
alexB is on a distinguished road
Hi Baris,
are you still working on that issue?
regards
Alex
alexB is offline   Reply With Quote
Old   April 23, 2015, 15:42
Baris (Heewa)
Hi Alex,
Yes I am still working about same topic.
Do you have any question?
B
Old   April 24, 2015, 09:51
Alexander Bartel
I didn't realize, that you are sure pretty experienced, so I assume that you aren't stuck at the same place like one year before...
I think i wanted to help you yeserday.
I currently try different things with InterPhaseChangeDyMFoam, but my problem is more a lack of c++ knowledge... thanks for your offered help and sorry for the unnecessary disturbance.
regards
Alex
Old   April 24, 2015, 10:45
Baris (Heewa)
Thank you for your kind consideration. Yes, i faced stability problem for a long time. However, finally i fixed and solved the problem.
I think that C++ is main problem for all new beginners. This can be also fixed in time with hard work
Please keep in touch and let me know about your challenge and brief findings in InterPhaseChangeDyMFoam.
BR
Baris
Old   May 19, 2015, 07:09
alvaro
alvariten is on a distinguished road
Hi people,
I have seen you are using interPhaseChangeFoam to simulate cavitation phenomena inside nozzle. Actually I'm working in this topic too. I have a question about this solver I hope you could answer me: interPhaseChangeFoam works with a hydrostatic pressure definition, isn't it? Did you do your simulations with this pressure definition or did you do any change?
And... to make this change, is it necessary to modify the pEqn.H file, or is there another easy way?
Regards,
Alvaro.
alvariten is offline   Reply With Quote
Old   May 19, 2015, 17:32
Alexander Bartel
Hi Alvaro,
did you try to work with the cavitatingBullet tutorial multiphase/InterPhaseChangeFoam/cavitatingBullet ?
You can change the geometry and customize it for your case.
regards
Alex
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
Old   May 19, 2015, 21:45
Baris (Heewa)
Hi Alvora,
Here hydrostatic pressure definition is just a kind of trick to simplify the boundary conditions and also increase the stability when the gravity should be considered. I just didnt understand why you want to change it? Finally, solver also calculate the total pressure as calculated and indicated in "CreateFields.H" P=p_rgh+rho*gh. As Alex said you can look at cavitatingBullet tutorial or last year i attended to CFD open course in Chalmers and already written a tutorial which explains cavitatingFoam and interPhaseChangeFoam for nozzle cavitation. You can also download and check it here: https://www.researchgate.net/publica...njector_Nozzle
BR.
Baris
alvariten likes this.
Old   May 20, 2015, 07:42
alvaro
I've seen your work Baris, and looks fine. I've tried to implement the code but I have a problem in the step to compile "phaseChangeTwoPhaseMixtures". The terminal returns me the following error and I don't know how to solve it.
alvaro@AlvaroPC:~/OpenFOAM/alvaro-2.3.0/applications/solvers/multiphase/TransportCavitatingFoam/phaseChangeTwoPhaseMixtures$ wmake
linux64GccDPOpt/options:5: *** missing separator.  Stop.
wmake error: file 'Make/linux64GccDPOpt/objectFiles' could not be created in /home/alvaro/OpenFOAM/alvaro-2.3.0/applications/solvers/multiphase/TransportCavitatingFoam/phaseChangeTwoPhaseMixtures
I have to warn you that I have no knowledge of C++ programming. This are the Make files.
Make/files
phaseChangeTwoPhaseMixture/phaseChangeTwoPhaseMixture.C
phaseChangeTwoPhaseMixture/newPhaseChangeTwoPhaseMixture.C
Kunz/Kunz.C
LIB = $(FOAM_USER_LIBBIN)/libphaseChangeTwoPhaseMixtures
Make/options
Kunz/Kunz.C
LIB_LIBS = \
    -L$(FOAM_USER_LIBBIN)
EXE_INC = \
    -I$(LIB_SRC)/transportModels/twoPhaseMixture/lnInclude \
    -I$(LIB_SRC)/transportModels \
    -I$(LIB_SRC)/transportModels/incompressible/lnInclude \
    -I$(LIB_SRC)/finiteVolume/lnInclude
LIB_LIBS = \
    -ltwoPhaseMixture \
    -ltwoPhaseProperties \
    -lincompressibleTransportModels \
    -lfiniteVolume
And the file options generated in the folder linux64GccDPOpt.
# 1 "options"
# 1 "<built-in>"
# 1 "<command-line>"
# 1 "options"
Kunz/Kunz.C
LIB_LIBS = -L$(FOAM_USER_LIBBIN)
EXE_INC = -I$(LIB_SRC)/transportModels/twoPhaseMixture/lnInclude -I$(LIB_SRC)/transportModels -I$(LIB_SRC)/transportModels/incompressible/lnInclude -I$(LIB_SRC)/finiteVolume/lnInclude
Could you help me to compile the case correctly?
Thanks.
Old   May 21, 2015, 04:13
alvaro
Hi again,
I ran the simulation with interPhaseChangeFoam and I obtained high negative pressure values. I think it's wrong, but why does this happen? How can I avoid that?
Regards
Old   May 21, 2015, 06:04
Alexander Bartel
Hi alvaro,
negativ pressure values aren't bad if they don't exceed -1e+05 Pa (-1bar) . I never gave it a thought, because I think its effective pressure and not absolute pressure plotted by paraView.
regards
Alex
Old   July 16, 2015, 04:43
Alexander Bartel
I think I have to correct myself.
I read in some posts, that p is the absolute pressure in InterPhaseChangeFoam, so you have discovered really an error.
Edit:
Now I have to correct/clarify my correction.
My first suggestion
is not wrong, but confusing, because my second statement
is also right.
As read here: InterPhaseChangeFoam ERROR
Originally Posted by pEqn.H
p == p_rgh + rho*gh;
p_rgh is the relative/effective pressure that is plotted by paraFoam
rho*gh is the atmospheric pressure
so everything is fine in my computation.
regards
Alex
Old   December 14, 2015, 08:27
jiri kozak
Kozan is on a distinguished road
Hello Alex,
I'm not completely sure that you are right.You can find something about the negative pressure issue in this tutorial:http://www.tfd.chalmers.se/~hani/kur...lenceModel.pdf
page 16
Regards
Jiř
Kozan is offline   Reply With Quote
Old   December 14, 2015, 20:10
Baris (Heewa)
Hi Jiri,
In that tutorial he also said that negative pressure is unrealistic condition.
. To prevent
from this unrealistic condition, one option is using a very high value for evaporation coefficient
Frankly speaking, according to my experience, absolute pressure can not be negative. However, somehow for a small duration a local pressure around bubbles can be measured negative in some experiments. This is definitely unrealistic conditions. (Because absolute pressure min can be 0 under the lab condition. look at the definition here: https://en.wikipedia.org/wiki/Pressu...nization_gauge) Therefore, if you have so small negative calculated value then you can ignore it.
BR
Baris
Old   December 15, 2015, 07:58
jiri kozak
Originally Posted by shipman View Post
Hi Jiri,
BR
Baris
Yes, I agree with this statemt. It was reaction to the last post. I have to confess that I read the thread only cursorily. On the other hand I thought that the tutorial could be useful. Have a nice day!
Regards,
Jiř
Thread Tools
Trackbacks are On
C-D nozzle supersonic jet boundary Gland FLUENT 4 May 24, 2012 00:25
Flow simulation in a Pelton turbine nozzle fivos FLUENT 0 April 19, 2011 11:46
how to simulate velocity field of supersonic gas (400m/s) from a nozzle to a chamber CYMa OpenFOAM 3 December 15, 2009 22:31
calculation of thrust thrugh a pipe with CD nozzle izhar Main CFD Forum 0 February 28, 2009 10:22
compressible flow in a counterflow nozzle d.vamsidhar FLUENT 0 November 24, 2005 02:45
