-   OpenFOAM Running, Solving & CFD (
-   -   How to setup second order schemes for all variables (
Many January 28, 2014 09:22
1 Attachment(s)
Hi Foamers,
I am here again because I am not understanding well how to setup fvSchemes for second order discretization for all variables.
I attach my case of a simpleFoam calculation with heat equation implemented. When I changes something the log files gives an error (something related to stack). I have only tried to put all schemes to linear and in laplacian terms I switched all to linear corrected. Are those second order schemes? What is the equivalence between put all second order schemes in FLUENT?
If somebody could give me any hint realted to the setup of my fvSchemes file it would be really aprecciated...
adambarfi January 28, 2014 10:35
see this link:
msuaeronautics January 28, 2014 13:28
You have specified first order upwinding on your divergence schemes.
If you want to use 2nd order upwind, the syntax is:
div(phi,U) Gauss linearUpwind grad(U)
The "grad(U)" term tacked on tells the code that you want to use the same gradient scheme (which is necessary) that you used on grad(U).
Many January 28, 2014 15:06
1 Attachment(s)
Thanks for all the replies. I have seen the page about numerical schemes in OF website, but it looks like there are several kinds of second order schemes and I am not sure which one could be the best for my problem.
If I use the setup suggested by msuaeronautics, I get an error message and the execution stops. I attach the log file.
Anybody have ideas?
Thanks in advance.
adambarfi January 29, 2014 00:41
according to your log file:
--> FOAM Warning :
    From function Foam::List<Foam::tetIndices> Foam::polyMeshTetDecomposition::faceTetIndices(const polyMesh&, label, label)
    in file meshes/polyMesh/polyMeshTetDecomposition/polyMeshTetDecomposition.C at line 570
    No base point for face 1754699, 4(53953 450466 860736 292725), produces a valid tet decomposition.
--> FOAM Warning : Suppressing any further warnings.
--> FOAM Warning :
    From function findElements::findElements(const fvMesh&)
    in file probes/probes.C at line 105
    Did not find location (0.021718 0.0177167 0.0168408) in any cell. Skipping location.
I think there is some problem in your grids. did you check it 'checkMesh'? what is the number of cells with skewness?
If your mesh is generated with snappyHexMesh, try the following:
In snappyhexMeshDict file, look for "minTetQuality".
//- Minimum quality of the tet formed by the face-centre
// and variable base point minimum decomposition triangles and
// the cell centre. Set to very negative number (e.g. -1E30) to
// disable.
// <0 = inside out tet,
// 0 = flat tet
// 1 = regular tet
For a regular tet, it should be positive. Try setting it to 1. If it does not work, set it to a very low positive number. Say 1e-10.
One way to check whether the issue with face tet is resolved or not before the start of the simulation is to do an "checkMesh -allGeometry". It will report if there are any issues with face tets.
Many January 29, 2014 14:47
Hi adambarfi,
Thanks for the reply. The mesh is created with snappy, but I have to disable quality controls at this step, because I am trying to introduce layers near the wall.
I will try this settings with another mesh (one that pass all checkMesh tests), but I think I'ĺl need more possibilities for second order numerical schemes. I am not sure which ones I am speciying and I am not understanding many things of OF website. If I want to use second order schemes, what changes have I to do in the fvSchemes file of my first post?
I have converged my case for the settings of this dictionary, but now I need to be sure my simulation is converging at least with second order, and I guess it will not be so easy. Maybe some changes are need to be done in fvSolution?
adambarfi January 30, 2014 06:58
AFAIK the fvSolution just controls the equation solvers, tolerances and algorithms. the discretization is set in the fvScheme.
in the OpenFOAM userGuide the way you can specify different discretization schemes is mentioned. For example, for gradient you can use 'Gauss <interpolationScheme>' and 'leastSquares' which are second order or you can use 'fourth' which is fourth order! ;)
in the same way you can change the Laplacian or Divergence schemes.
Tobi January 30, 2014 07:25
Hello Many,
to know which schemes are available you can use the banana trick:
div(U,phi)        banana;
After starting the solver you will find a message which schemes you can use.
Additionally you can have a look at my homepage. There I investigated numerical schemes in a very simple geometry.
Still just in german.
But you can see that all schemes except of the gauss upwind can calculate un-phyisical results.
In most cases I use 2nd order limited schemes to avoid un-physical results. Additionally you see that the
results depend on the mesh and the flow direction passing through the cells.
Especially with scalar Transport equations in which the variable is defined in a interval.
- i made a very huge Research of the SLFM (laminar steady flamelet model). Therefor all physical varables phi can be described with Z and Z_var.
Those two variables are valid in the interval:
0 <= Z <= 1              // 0 = oxidator      1 = fuel
0 <= Z_var <= 0.25    // 0 = no turbulence          0.25 maxium turbulence
Therefor I use limited limited 2nd order schemes:
div(phi,Z)            Gauss limitedLimitedLinear 1 0 1;
div(phi,Z_var)      Gauss limitedLimitedLinear 1 0 0.25;
The first number is for the limiter:
-> 1 full limiter function
-> 0 non limiter function
Therefor the following Expression should be the same (I am not 100% sure):
Gauss limitedLinear 0;      // 2nd Order with limiter function but limiter weight = 0
Gauss linear;                  // 2nd Order
The second and third value are the lower and upper bounds for the variable.
Hope it is getting clear.
Regards Tobi
Many January 30, 2014 15:07
Thanks Mostafa and Tobias for your help,
Mostafa, I'll try with leastSquares. Anyway I'll give a sight at OF Userś Guide again.
Tobias, I know your web page. I have been reading some of your post and they are great. Nice to meet you. I would like to understand what you are doing in your research about numerical schemes, but I don't speak German so it will be a mess!
My problem is an airflow inside a nose. I can get converged results with Gauss linear for gradients, Gauss upwind for divergence terms and Gauss linear uncorrected for laplacians. But to be sure that my results are OK I'd like to switch to second order (I guess this means to put linear instead of upwind in divergences, and Gauss linear corrected for laplacian). With those settings simulation just crashes after 2 iterations.I don't expect to converge it at the first try, but I cannot understand why it crashes...
I'll keep trying anyway!
Tobi January 31, 2014 12:55
thanks for your feedback and the words.
I will translate my page into english as soon as I can and additionally I will make more schemes analyses.
wenxu November 19, 2014 03:56
Dear Mostafa Mahmoudi,
please see this link and help me..
thank you in advance.
wenxu November 19, 2014 04:14
Dear Tobias,
when i use the upwind scheme for the div(phi,U), the simulation results is somehow reasonable. But when i changed it into linear,the maximum value of velocity will be two times as the inlet value and the flow field seems terrible. please see my link: and help me. thank you very much!
PS: i also do research on turbulent combustion model resently, i need your precious guideness.
best wishes,
Phil_ November 19, 2014 10:15
Is this specific for linearUpwind? And it is necessary to use the same gradient scheme used in grad(U)? Why is that?
Best regards
wenxu November 19, 2014 10:42
Best regards
  • Surely no, such as LUST also use the same form.
  • I think that't not necessary, i use the cellMDLimited Gauss linear 1; for the div(phi,U),and the grad(U) i use linear.(i think this may be the openfoam's dictionary function,that we can simpilfy the use of fvScheme , we can use the grad(U) to substitute for the cellMDLimited Gauss linear 1; long characters...:) )
adambarfi November 19, 2014 12:52
sorry, I didn't get the question!!! but it seems Tobi answered you and you got it.
wenxu November 19, 2014 20:45
Yeah,Mostafa, Thank you all the same!
