How to calculate the field value of a arbitrary point
Like Tree1Likes
  • 1 Post By eugene
Old   April 11, 2005, 04:13
Default Given a position as (x,y,z), I
Luckyluke
luckyluke is on a distinguished road
Given a position as (x,y,z), I want the u or p value in this point by using interpolation.
Thanks all.
luckyluke is offline   Reply With Quote
Old   April 11, 2005, 05:20
Default As a postprocessing step use t
Mattijs Janssens
mattijs is on a distinguished road
As a postprocessing step use the 'sample' utility.
Inside a code use the probe functionality (See e.g. oodles/createProbes.H). This does no interpolation however.
mattijs is offline   Reply With Quote
Old   April 11, 2005, 06:51
Default Hi,Mattijs. I can find out the
Luckyluke
Hi,Mattijs. I can find out the cell which contain the given point (x,y,z) using mesh.finCell(), then how I can know the cell's neighbour cells?
Thanks.
Old   April 11, 2005, 07:18
Default vector probePoint(x,y,z); lab
Eugene de Villiers
eugene is on a distinguished road
label probeCell = mesh.findCell(probePoint);
const labelList& probeCellNeighbours = mesh.cellCells()[probeCell];
forAll(probeCellNeighbours, cellI)
Do your stuff
But if you want to interpolate, you might want to look at the built-in interpolation classes.
Kummi likes this.
eugene is offline   Reply With Quote
Old   April 11, 2005, 08:13
Default Thank all. By the way, if I kn
Luckyluke
Thank all. By the way, if I knew the 'label' of one cell,e.g. cellI, then I can access the field value of this cell using U[cellI]. Is that right?
Can a field loop be performed as follows:
forALL(mesh.cells(),i) {U[i]=...}
Or
forALL(U,i) {U[i]=...}?
These are simple questions. Could anybody give me a answer?
Old   April 11, 2005, 08:25
Default Right Both forALL(mesh.ce
Eugene de Villiers
Right
Both
and
will give you the same result, i.e. the ordering of cells and volFields are identical.
Most operations however do not require that you loop over the cells explicitly as they can be performed using field algebra.
Old   October 19, 2012, 05:45
Default How can get my results at the patch using points' coordinates
hfs
hfs is on a distinguished road
Do your stuff
I need the same BUT!:
I am doing a comparison between wind tunnel results and OpenFOAM simulation. Available from wind tunnel are the pressure coefficients (Cp) on 32 points. The coordinates of those points are available. I need to get P field on the body patch at those 32 points.
I mean, the coordinates of a point may not guarantee that It belongs to the patch (due to lack of accuracy of snappyHexMesh). How can get my results at the patch using points' coordinates?
hfs is offline   Reply With Quote
Old   February 28, 2014, 15:14
Ripudaman Manchanda
ripudaman is on a distinguished road
HFS, were you able to find a solution to your problem? I have a similar concern. I am using stressAnalysisFoam and I need the D field on the body patch at a particular point as well.
ripudaman is offline   Reply With Quote
How to find out the cell containing a arbitrary point luckyluke OpenFOAM Running, Solving & CFD 2 July 10, 2013 11:54
Torque Calculation at Arbitrary Point Mojtaba CFX 8 March 1, 2009 00:22
Torque Calculation at Arbitrary Point Mojtaba Main CFD Forum 0 February 14, 2009 00:58
Calculation torque on arbitrary point Mojtaba Main CFD Forum 0 February 9, 2009 00:08
Calculation torque on arbitrary point Mojtaba CFX 0 February 6, 2009 23:45
