-   -   Physical model: MRF RANS (http://www.cfd-online.com/Forums/openfoam-solving/129249-physical-model-mrf-rans.html)
Ruli January 31, 2014 18:11
Dear Foamers,
again I have a question. I am simulating a wind turbine, using SIMPLE, the MRF approach with a 120 wedge and cyclic boundaries and RANS (kOmegaSST) turbulence modelling.
Currently I am trying to figure out the exact physical equations I am actually using.
I do know and understand:
- the Navier Stokes equation and its RANS formulation
- the formulation of the Navier Stokes equation in its MRF formuation (from here: http://openfoamwiki.net/index.php/Se...RF_development)
What I don't understand:
- How do both formulations look like in combination?
- Does MRFSource in fvOptions only add the Coriolis term?
- Would the MRF approach work for unsteady flows? As I understand, for unsteady flow there have to be considered further time-dependent terms.
If somebody knows a helpful reference or already has figured it out, I would be greatful for any help. I am not very experienced in reading the source code, but I am also thankful for hints, where in the code to look.
Best regards
Julian
Ruli February 5, 2014 11:22
my current thoughts:
The formula looks like the one described in the link above, but instead of kinematic viscosity (nu) I simply have (nu + nut).
Does that sound right?
Best regards
Julian
farhhad February 5, 2014 11:25
as far as I know you can use pimpleFoam (an unsteady solver) with fvOption where you'll be able to add MRF zones. I believe you can use any turbulence model available with pimple.
best
Ruli February 15, 2014 09:21
Dear farhad,
thanks for your reply. Good to know, that fvOptions does work with pimple, too.
Any other suggestions, how the Navier Stokes equation looks in the combined MRF + RANS formulation?
Best regards
Julian
GerhardHolzinger February 17, 2014 07:14
Originally Posted by Ruli (Post 472836)
Dear Foamers,
Best regards
Julian
the file MRFZone.C contains a method called correctBoundaryVelocity(). There the velocity at all boundaries within the MRFZone are corrected, i.e. the solid body rotation is applied.
void Foam::MRFZone::correctBoundaryVelocity(volVectorField& U) const
    const vector Omega = this->Omega();
    // Included patches
    forAll(includedFaces_, patchi)
        const vectorField& patchC = mesh_.Cf().boundaryField()[patchi];
        vectorField pfld(U.boundaryField()[patchi]);
        forAll(includedFaces_[patchi], i)
            label patchFacei = includedFaces_[patchi][i];
            pfld[patchFacei] = (Omega ^ (patchC[patchFacei] - origin_));
        U.boundaryField()[patchi] == pfld;
