Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam222/platforms/linux64GccDPO
Hi all,
While simulating for the problem, i got the following error, eatin@EAT-Standalone:~/ADARSH/cavity$ rhoSimpleFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.2 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.2-9240f8b967db Exec : rhoSimpleFoam Date : Feb 03 2014 Time : 16:21:26 Host : "EAT-Standalone" PID : 7620 Case : /home/eatin/ADARSH/cavity nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 SIMPLE: convergence criteria field p tolerance 1e-06 field U tolerance 1e-06 field h tolerance 1e-06 field k tolerance 1e-06 field omega tolerance 1e-06 Reading thermophysical properties Selecting thermodynamics package { type hePsiThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting RAS turbulence model kOmegaSST kOmegaSSTCoeffs { alphaK1 0.85034; alphaK2 1; alphaOmega1 0.5; alphaOmega2 0.85616; Prt 1; gamma1 0.5532; gamma2 0.4403; beta1 0.075; beta2 0.0828; betaStar 0.09; a1 0.31; b1 1; c1 10; F3 false; } No finite volume options present Starting time loop Time = 0.005 GAMG: Solving for Ux, Initial residual = 1, Final residual = 9.76443e-07, No Iterations 115 GAMG: Solving for Uy, Initial residual = 1, Final residual = 9.71495e-07, No Iterations 61 GAMG: Solving for Uz, Initial residual = 1, Final residual = 9.75421e-07, No Iterations 116 DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 8.10833e-07, No Iterations 69 GAMG: Solving for p, Initial residual = 0.999137, Final residual = 0.00126243, No Iterations 1000 time step continuity errors : sum local = 6.93746e-12, global = 3.97247e-14, cumulative = 3.97247e-14 rho max/min : 1.5 1.36693 GAMG: Solving for omega, Initial residual = 0.213657, Final residual = 2.02712e-08, No Iterations 2 GAMG: Solving for k, Initial residual = 1, Final residual = 1.7107e-07, No Iterations 2 ExecutionTime = 72.46 s ClockTime = 72 s Time = 0.01 GAMG: Solving for Ux, Initial residual = 0.852602, Final residual = 9.3075e-07, No Iterations 59 GAMG: Solving for Uy, Initial residual = 0.866457, Final residual = 8.52692e-07, No Iterations 57 GAMG: Solving for Uz, Initial residual = 0.875269, Final residual = 9.25048e-07, No Iterations 63 DILUPBiCG: Solving for h, Initial residual = 0.116407, Final residual = 8.73549e-07, No Iterations 61 GAMG: Solving for p, Initial residual = 0.660759, Final residual = 6.79783e-07, No Iterations 1000 time step continuity errors : sum local = 6.85625e-12, global = -9.17279e-15, cumulative = 3.05519e-14 rho max/min : 1.5 1.37284 GAMG: Solving for omega, Initial residual = 0.173706, Final residual = 4.94879e-10, No Iterations 2 GAMG: Solving for k, Initial residual = 0.979579, Final residual = 3.70192e-10, No Iterations 2 ExecutionTime = 139.7 s ClockTime = 140 s Time = 0.015 GAMG: Solving for Ux, Initial residual = 0.885481, Final residual = 9.79136e-07, No Iterations 68 GAMG: Solving for Uy, Initial residual = 0.924134, Final residual = 9.63321e-07, No Iterations 65 GAMG: Solving for Uz, Initial residual = 0.90357, Final residual = 8.69081e-07, No Iterations 69 DILUPBiCG: Solving for h, Initial residual = 0.0601542, Final residual = 4.73406e-07, No Iterations 64 GAMG: Solving for p, Initial residual = 0.814731, Final residual = 9.26881e-09, No Iterations 143 time step continuity errors : sum local = 3.72959e-11, global = 1.38386e-13, cumulative = 1.68938e-13 rho max/min : 1.5 1.37284 GAMG: Solving for omega, Initial residual = 0.208416, Final residual = 1.47666e-08, No Iterations 2 GAMG: Solving for k, Initial residual = 0.970247, Final residual = 9.02517e-08, No Iterations 2 ExecutionTime = 160.3 s ClockTime = 160 s Time = 0.02 #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::GaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #4 Foam::GaussSeidelSmoother::smooth(Foam::Field<doub le>&, Foam::Field<double> const&, unsigned char, int) const in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #5 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #6 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #7 in "/opt/openfoam222/platforms/linux64GccDPOpt/bin/rhoSimpleFoam" #8 in "/opt/openfoam222/platforms/linux64GccDPOpt/bin/rhoSimpleFoam" #9 in "/opt/openfoam222/platforms/linux64GccDPOpt/bin/rhoSimpleFoam" #10 in "/opt/openfoam222/platforms/linux64GccDPOpt/bin/rhoSimpleFoam" #11 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #12 in "/opt/openfoam222/platforms/linux64GccDPOpt/bin/rhoSimpleFoam" Floating point exception (core dumped) Initially i was solving with smoothSolver but later I have chaged the solver from smoothSolver to GAMG, also reduced the relaxation factor, but still getting the same O/P |
Lots of reasons may lead to this error (bad IC/BC, bad settings for GAMG solver etc). Try using PBiCG instead of GAMG (or maybe first use DICGaussSeidel as a smoother for GAMG, as the error was during smooth method call). |
greetings Alexeym,
First of all thanks for your quick response. I have tried all the ways you mentioned, and again faced the same problem. later I changed the pressure solver to PCG, with preconditioner DIC, but again the same issue arises. I have pointed out few interesting things in the solution: Create time Create mesh for time = 0 SIMPLE: convergence criteria field p tolerance 1e-06 field U tolerance 1e-06 field h tolerance 1e-06 field k tolerance 1e-06 field omega tolerance 1e-06 Reading thermophysical properties Selecting thermodynamics package { type hePsiThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting RAS turbulence model kOmegaSST kOmegaSSTCoeffs { alphaK1 0.85034; alphaK2 1; alphaOmega1 0.5; alphaOmega2 0.85616; Prt 1; gamma1 0.5532; gamma2 0.4403; beta1 0.075; beta2 0.0828; betaStar 0.09; a1 0.31; b1 1; c1 10; F3 false; } No finite volume options present Starting time loop Time = 0.005 DILUPBiCG: Solving for Ux, Initial residual = 1, Final residual = 9.4729e-07, No Iterations 49 DILUPBiCG: Solving for Uy, Initial residual = 1, Final residual = 8.8146e-07, No Iterations 56 DILUPBiCG: Solving for Uz, Initial residual = 1, Final residual = 8.02978e-07, No Iterations 48 DILUPBiCG: Solving for h, Initial residual = 1, Final residual = 8.10833e-07, No Iterations 69 DICPCG: Solving for p, Initial residual = 0.999137, Final residual = 9.13645e-07, No Iterations 211 DICPCG: Solving for p, Initial residual = 0.00897964, Final residual = 8.85922e-07, No Iterations 166 DICPCG: Solving for p, Initial residual = 0.00164253, Final residual = 9.66848e-07, No Iterations 157 DICPCG: Solving for p, Initial residual = 0.00077649, Final residual = 9.73811e-07, No Iterations 145 DICPCG: Solving for p, Initial residual = 0.000255178, Final residual = 9.7144e-07, No Iterations 144 time step continuity errors : sum local = 4.81219e-11, global = 1.99058e-13, cumulative = 1.99058e-13 rho max/min : 1.5 1.36693 smoothSolver: Solving for omega, Initial residual = 0.213657, Final residual = 4.49362e-13, No Iterations 2 DILUPBiCG: Solving for k, Initial residual = 1, Final residual = 3.25225e-08, No Iterations 2 ExecutionTime = 30.38 s ClockTime = 31 s Time = 0.01 DILUPBiCG: Solving for Ux, Initial residual = 0.853572, Final residual = 9.17802e-07, No Iterations 73 DILUPBiCG: Solving for Uy, Initial residual = 0.867465, Final residual = 9.01878e-07, No Iterations 76 DILUPBiCG: Solving for Uz, Initial residual = 0.878958, Final residual = 9.35019e-07, No Iterations 74 DILUPBiCG: Solving for h, Initial residual = 0.116405, Final residual = 8.7348e-07, No Iterations 61 DICPCG: Solving for p, Initial residual = 0.635366, Final residual = 9.3124e-07, No Iterations 217 DICPCG: Solving for p, Initial residual = 0.0104651, Final residual = 9.48305e-07, No Iterations 168 DICPCG: Solving for p, Initial residual = 0.00204681, Final residual = 9.85206e-07, No Iterations 158 DICPCG: Solving for p, Initial residual = 0.000909866, Final residual = 9.84431e-07, No Iterations 149 DICPCG: Solving for p, Initial residual = 0.000311013, Final residual = 9.3295e-07, No Iterations 144 time step continuity errors : sum local = 7.74558e-10, global = -4.21626e-11, cumulative = -4.19635e-11 rho max/min : 1.5 1.37284 smoothSolver: Solving for omega, Initial residual = 0.173706, Final residual = 2.81439e-14, No Iterations 2 DILUPBiCG: Solving for k, Initial residual = 0.979579, Final residual = 2.70355e-09, No Iterations 2 ExecutionTime = 60.54 s ClockTime = 61 s Time = 0.015 DILUPBiCG: Solving for Ux, Initial residual = 0.882737, Final residual = 7.38937e-07, No Iterations 104 DILUPBiCG: Solving for Uy, Initial residual = 0.923639, Final residual = 9.97728e-07, No Iterations 107 DILUPBiCG: Solving for Uz, Initial residual = 0.910762, Final residual = 6.60213e-07, No Iterations 102 DILUPBiCG: Solving for h, Initial residual = 0.0603949, Final residual = 9.20886e-07, No Iterations 62 DICPCG: Solving for p, Initial residual = 0.791538, Final residual = 9.74006e-07, No Iterations 219 DICPCG: Solving for p, Initial residual = 0.0109548, Final residual = 9.2436e-07, No Iterations 170 DICPCG: Solving for p, Initial residual = 0.00235946, Final residual = 9.63775e-07, No Iterations 159 DICPCG: Solving for p, Initial residual = 0.00100188, Final residual = 9.7107e-07, No Iterations 150 DICPCG: Solving for p, Initial residual = 0.000361423, Final residual = 9.80694e-07, No Iterations 144 time step continuity errors : sum local = 2.57303e-07, global = 8.75624e-09, cumulative = 8.71428e-09 rho max/min : 1.5 1.37284 smoothSolver: Solving for omega, Initial residual = 0.208342, Final residual = 1.51846e-10, No Iterations 2 DILUPBiCG: Solving for k, Initial residual = 0.970282, Final residual = 9.42625e-08, No Iterations 2 ExecutionTime = 93.65 s ClockTime = 94 s Time = 0.02 DILUPBiCG: Solving for Ux, Initial residual = 0.751383, Final residual = 34.257, No Iterations 1001 DILUPBiCG: Solving for Uy, Initial residual = 0.822324, Final residual = 857.331, No Iterations 1001 DILUPBiCG: Solving for Uz, Initial residual = 0.777107, Final residual = 71.3373, No Iterations 1001 DILUPBiCG: Solving for h, Initial residual = 0.999996, Final residual = 8.43945e-07, No Iterations 173 DICPCG: Solving for p, Initial residual = 0.994674, Final residual = 1.2802, No Iterations 1001 DICPCG: Solving for p, Initial residual = 0.44538, Final residual = 1.03715, No Iterations 1001 DICPCG: Solving for p, Initial residual = 0.622246, Final residual = 4.07268, No Iterations 1001 DICPCG: Solving for p, Initial residual = 0.815726, Final residual = 3.39158, No Iterations 1001 DICPCG: Solving for p, Initial residual = 0.849077, Final residual = 1.77735, No Iterations 1001 time step continuity errors : sum local = 15810.8, global = 0.0563862, cumulative = 0.0563862 rho max/min : 1.5 0.5 #0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #2 in "/lib/x86_64-linux-gnu/libc.so.6" #3 at smoothSolver.C:0 #4 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libOpenFOAM.so" #5 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libfiniteVolume.so" #6 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam222/platforms/linux64GccDPOpt/bin/rhoSimpleFoam" #7 Foam::fvMatrix<double>::solve() in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so" #8 Foam::compressible::RASModels::kOmegaSST::correct( ) in "/opt/openfoam222/platforms/linux64GccDPOpt/lib/libcompressibleRASModels.so" #9 in "/opt/openfoam222/platforms/linux64GccDPOpt/bin/rhoSimpleFoam" #10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #11 in "/opt/openfoam222/platforms/linux64GccDPOpt/bin/rhoSimpleFoam" Floating point exception (core dumped) here we can see that at time t=0.02 time step continuity error increases dramatically and hence everything messed up, also the number of iterations are also increases drastically. I have also tried to solve by keeping turbulence model off, followed by reducing the relaxation factor and increasing the orthogonalCorrectors and very sad to say that nothing works, it is facing the same problem :( |
Surely I can keep guessing, you can keep checking if my guess is wrong or not. But simpler solution is: 1. Post your case files 2. If 1 is for some reason unacceptable, post (in CODE blocks or as attached files): - short case description - checkMesh output - boundary conditions - initial conditions - fvSchemes & fvSolution |
5 Attachment(s)
hi
actually i had imported the mesh file from fluent, later i modified the case files of the 'cavity' to make it for my case. i have uploaded the new case files here. after looking at the simulation i can say that the problem may be with pressure entry only. i have changed the solvers from GAMG to smoothSolver and what not :D. i have also switched off the turbulence for each solvers and later again turned on. but i don't know what is preventing it to get the solutions. the checkMesh output is written here. // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create polyMesh for time = 0 Time = 0 Mesh stats points: 341856 faces: 1000065 internal faces: 974907 cells: 329162 faces per cell: 6 boundary patches: 4 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 329162 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 0 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology HOUSING 13658 13832 ok (non-closed singly connected) VALVE 5076 5106 ok (non-closed singly connected) INLET 5060 5178 ok (non-closed singly connected) OUTLET 1364 1394 ok (non-closed singly connected) Checking geometry... Overall domain bounding box (-12.15 -31 0.108183) (12.15 11 32.25) Mesh (non-empty, non-wedge) directions (1 1 1) Mesh (non-empty) directions (1 1 1) Boundary openness (-2.43187e-16 1.67233e-17 -4.02264e-16) OK. Max cell openness = 1.92396e-14 OK. Max aspect ratio = 624.06 OK. Minimum face area = 7.0046e-05. Maximum face area = 0.767025. Face area magnitudes OK. Min volume = 1.51164e-05. Max volume = 0.291075. Total volume = 16674.7. Cell volumes OK. Mesh non-orthogonality Max: 65.3276 average: 15.3553 Non-orthogonality check OK. Face pyramids OK. Max skewness = 2.55632 OK. Coupled point location match (average 0) OK. Mesh OK. End |
I don't know why you've decided that it will be very comfortable to read files from screenshots. It was actually rather annoying. You've got mesh with max non-orthogonality = 65, so 1. Increase the number of nNonOrthogonalCorrectors 2. Use cellMDLimited and faceMDLimited schemes for gradient schemes 3. Switch from corrected to limited in laplacian and snGrad schemes 4. Reduce time step |
Hi Alexeym,
First of all sorry for the inconvinience caused. as per the instructions i have changed the required entries and the files are mentioned here [controlDict] [//*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.2 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application rhoSimpleFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 1; deltaT 1e-4; writeControl timeStep; writeInterval 100; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression uncompressed; timeFormat general; timePrecision 6; runTimeModifiable yes; // ************************************************** *********************** //] [fvSolutions] [//*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.2 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver GAMG; tolerance 1e-08; relTol 0; smoother GaussSeidel; cacheAgglomeartion true; nCellsInCoarsestLevel 100; agglomerator faceAreaPair; mergeLevels 1; } U { solver smoothSolver; smoother GaussSeidel; nSweeps 2; tolerance 1e-06; relTol 0; } h { solver PBiCG; preconditioner DILU; tolerance 1e-06; relTol 0; } k { solver smoothSolver; smoother GaussSeidel; nSweeps 2; tolerance 1e-08; relTol 0; } omega { solver smoothSolver; smoother GaussSeidel; nSweeps 2; tolerance 1e-08; relTol 0; } } SIMPLE { nNonOrthogonalCorrectors 10; //0; nCorrectors 10; rhoMin rhoMin [1 -3 0 0 0] 0.5; rhoMax rhoMax [1 -3 0 0 0] 1.5; residualControl { p 1e-6; U 1e-6; h 1e-6; k 1e-6; omega 1e-6; } } relaxationFactor { p 0.02; rho 0.02; U 0.02; k 0.02; omega 0.02; h 0.02; } // ************************************************** *********************** //] [fvSchemes] [//*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.2 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; //cavity } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState; } gradSchemes { default cellLimited; //Gauss linear; grad(U) cellMDLimited; //Gauss linear; grad(p) faceMDLimited; //Gauss linear; } divSchemes { div(phi,U) bounded Gauss; div((muEff*dev2(T(grad(U))))) Gauss linear; div(phi,h) Gauss upwind; div(phi,omega) Gauss upwind; div(phi,k) Gauss upwind; div(phi,K) Gauss upwind; div(phid,p) Gauss upwind; div(U,p) Gauss upwind; //div(phi,U) bounded Gauss upwind; //div((muEff*dev2(T(grad(U))))) Gauss linear; //div(phi,e) bounded Gauss upwind; //div(phi,epsilon) bounded Gauss upwind; //div(phi,k) bounded Gauss upwind; //div(phi,Ekp) bounded Gauss upwind; } laplacianSchemes { laplacian(muEff,U) Gauss linear limited; //corrected; laplacian(alphaEff,h) Gauss linear limited; //corrected laplacian((rho|A(U)),p) Gauss linear limited; //corrected laplacian((rho*rAU),p) Gauss linear limited; //corrected laplacian(DomegaEff,omega) Gauss linear limited; //corrected laplacian(DkEff,k) Gauss linear limited; //corrected laplacian(1,p) Gauss linear limited; //corrected laplacian((rho*(1|A(U))),p) Gauss linear limited; //corrected //laplacian(alphaEff,e) Gauss linear corrected; //laplacian(muEff,U) Gauss linear corrected; //laplacian(alphaEff,e) Gauss linear corrected; //laplacian((rho*(1|A(U))),p) Gauss linear corrected; //laplacian(DepsilonEff,epsilon) Gauss linear corrected; //laplacian(DkEff,k) Gauss linear corrected; } interpolationSchemes { default linear; div(U,p) upwind phi; } snGradSchemes { default limited; } fluxRequired { default no; p ; } // ************************************************** *********************** //] while simulating I got the following error [o/p in terminal][/eatin@EAT-Standalone:~$ cd ADARSH/cavity/ eatin@EAT-Standalone:~/ADARSH/cavity$ rhoSimpleFoam /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.2.2 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.2.2-9240f8b967db Exec : rhoSimpleFoam Date : Feb 05 2014 Time : 16:43:18 Host : "EAT-Standalone" PID : 14673 Case : /home/eatin/ADARSH/cavity nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Disallowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 SIMPLE: convergence criteria field p tolerance 1e-06 field U tolerance 1e-06 field h tolerance 1e-06 field k tolerance 1e-06 field omega tolerance 1e-06 Reading thermophysical properties Selecting thermodynamics package { type hePsiThermo; mixture pureMixture; transport const; thermo hConst; equationOfState perfectGas; specie specie; energy sensibleEnthalpy; } Reading field U Reading/calculating face flux field phi Creating turbulence model Selecting RAS turbulence model kOmegaSST --> FOAM FATAL IO ERROR: Grad scheme not specified Valid grad schemes are : 9 ( Gauss cellLimited cellMDLimited edgeCellsLeastSquares faceLimited faceMDLimited fourth leastSquares pointCellsLeastSquares ) file: /home/eatin/ADARSH/cavity/system/fvSchemes.gradSchemes.grad(U) at line 26. From function gradScheme<Type>::New(const fvMesh& mesh, Istream& schemeData) in file /home/opencfd/OpenFOAM/OpenFOAM-2.2.2/src/finiteVolume/lnInclude/gradScheme.C at line 54. FOAM exiting ] I have changed several times the same entries, also sometimes the schemes mentioned but the error got worse :( <sad :D> thanks in advance, Adarsh |
If you read a little bit of documentation (for example here http://openfoam.org/docs/user/fvSchemes.php), you'd know that you should put in fvSchemes not just Code:
cellLimited Code:
cellLimited Gauss linear 1; |
hi Alexeym,
initially it seems to be working but at time-step no. 50 it stopped and gave a message of 'core dumped'. I have tried to solve the issue simply by editing the tutorial files and you would be happy to know that its workig fine. one most importat thing to mention, THANK YOU FOR YOUR QUICK AND VALUABLE SUGGESTIONS. :) :) with best regards, Adarsh |
Problem simulation
Hi, i'm trying to simulate a wing and i have this problem...
I do checkMesh and is ok, so i don't know where is the problem. I try de solutions that are in this post but i can't simulate. Trank you. /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5.x | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 5.x-197d9d3bf20a Exec : simpleFoam Date : May 17 2018 Time : 12:53:20 Host : "David-HP" PID : 25925 I/O : uncollated Case : /home/david/Escritorio/airFoil2D nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 SIMPLE: convergence criteria field p tolerance 1e-05 field U tolerance 1e-05 field nuTilda tolerance 1e-05 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model type RAS Selecting RAS turbulence model SpalartAllmaras Selecting patchDistMethod meshWave RAS { RASModel SpalartAllmaras; turbulence off; printCoeffs on; sigmaNut 0.66666; kappa 0.41; Cb1 0.1355; Cb2 0.622; Cw2 0.3; Cw3 2; Cv1 7.1; Cs 0.3; } No MRF models present No finite volume options present Starting time loop Time = 1 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::GaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) at ??:? #4 Foam::GaussSeidelSmoother::smooth(Foam::Field<doub le>&, Foam::Field<double> const&, unsigned char, int) const at ??:? #5 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #6 ? at ??:? #7 ? at ??:? #8 ? at ??:? #9 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #10 ? at ??:? Excepción de coma flotante (`core' generado) For ControlDict: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application simpleFoam; startFrom latestTime; startTime 0; stopAt endTime; endTime 500; deltaT 1; writeControl timeStep; writeInterval 2; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; // ************************************************** *********************** // fvschemes; /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState; } gradSchemes { default cellLimited Gauss linear; grad(U) cellMDLimited Gauss linear 1; grad(p) faceMDLimited Gauss linear 1; } divSchemes { default none; div(phi,U) Gauss linear; div(phi,nuTilda) Gauss linear; div((nuEff*dev2(T(grad(U))))) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; div(U,p) upwind phi; } snGradSchemes { default limited; } wallDist { method meshWave; } // ************************************************** *********************** // fvSolutions: /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 5 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver GAMG; tolerance 1e-08; relTol 0.1; smoother GaussSeidel; cacheAgglomeartion true; nCellsInCoarsestLevel 100; agglomerator faceAreaPair; mergeLevels 1; } U { solver smoothSolver; smoother GaussSeidel; nSweeps 2; tolerance 1e-06; relTol 0.1; } nuTilda { solver smoothSolver; smoother GaussSeidel; nSweeps 2; tolerance 1e-08; relTol 0.1; } } SIMPLE { nNonOrthogonalCorrectors 10; nCorrectors 10; pRefCell 0; pRefValue 0; residualControl { p 1e-5; U 1e-5; nuTilda 1e-5; } } relaxationFactors { fields { p 0.3; } equations { U 0.7; nuTilda 0.7; } } // ************************************************** *********************** // I do checkMesh and is ok, so i don't know where is the problem. I try de solutions that are in this post but i can't simulate. Trank you. |
