cyclicAMI / cyclicACMI OF 2.3
Old   February 21, 2014, 09:36
Default cyclicAMI / cyclicACMI OF 2.3
Peter Müller is on a distinguished road
Hi together
Just downloaded 2.3 and tried to play around a little bit. I'm wondering little bit about the split btw. cyclicAMI and cyclicACMI and would be really happy if somebody could explain me a little better.
cyclicAMI: The say that for "low weight" it uses kind of a zeroGradient boundary condition. So can this be used as "bridgeOverlap" of 1.5 version? I guess zeroGradient is not really appropriate for any kind of flow quantity at a wall...
cyclicACMI: The implementation of a "bridgeOverlap" function seams to be better here but I was unable to use cyclicACMI for a "rotational" geometry yet. It always tells me
--> FOAM FATAL ERROR:
Inconsistent ACMI patches AMI1 and AMI2. Patches should have identical topology
Is it possible at all to use cyclicACMI for rotational transformation?
Thanks for all kind of explanation
Peter Müller is offline   Reply With Quote
CyclicAMI BC preservePatches Parallel Run - again!?! hxaxtma OpenFOAM Pre-Processing 4 August 31, 2015 17:47
problem with cyclicAMI and wall distance Maff OpenFOAM Bugs 5 August 14, 2014 14:41
CyclicAMI: Problems with pressure field Thoma OpenFOAM Running, Solving & CFD 13 June 28, 2014 08:34
CyclicAMI Issue In OpenFOAM 2.2.0 prasant OpenFOAM Running, Solving & CFD 17 March 16, 2013 02:00
difference between cyclic and cyclicAMI? sachinlb OpenFOAM Running, Solving & CFD 0 November 5, 2012 05:20
