Home > Forums > OpenFOAM Running, Solving & CFD
read result values with pyFoam
Old   February 7, 2014, 04:40
Default read result values with pyFoam
Davide Pasini
ilpaso is on a distinguished road
Hi Foamers!
I'm trying to read the average p values on a patch with python.
What is the right way?
Yes, I'm a newbie
I have done some tests with pyFoam.
I'm able to modify the boundary condictions and run the solver but nothing in order to read the result values and convert in a "python" format.
I don't know if reading the csv output file is an easy way to read the openFoam outputs in python.
This is the function I wrote in controlDict in order to do that.
pressureAverage
        type patchAverage;
        fields (
            p
        patches (
            velocity-inlet-6
	expression "p";
        outputFileMode csv;
	verbose true;
thank you
Regards
ilpaso is offline   Reply With Quote
Old   February 11, 2014, 05:32
Davide Pasini
Hi again,
Any ideas to help me?
Thank you
Old   February 13, 2014, 19:45
Assistant Moderator
Bernhard Gschaider
Originally Posted by ilpaso View Post
Hi Foamers!
Yes, I'm a newbie
pressureAverage
        type patchAverage;
        fields (
            p
        patches (
            velocity-inlet-6
	expression "p";
        outputFileMode csv;
	verbose true;
thank you
Regards
The PyFoam-parser for OpenFOAM-files is quote flexible but the price for this is that it is not very good at reading the results of simulations (if they are bigger than a few thousand cells). It COULD be extended to properly read field data and convert it into numpy-arrays but in my opinion the use of this would be limited as information about the mesh is not available that way (don't know what you mean with "average" but the arithmetic average only makes sense if all faces are of the same size).
Usually I do such calculations in a functionObject. The way you're sketching it. If this is the patchAverage from swak4Foam? Then you already should have a csv file in the case (exact location depends on the version of swak you're using).
Or is your problem READING that CSV-file?
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   February 14, 2014, 07:34
Davide Pasini
Thank you gschaider for your reply.
I'm trying to couple a 0D circuit with a 3D vessel.
For the 0d simulation I use OpenModelica, OpenFoam for the 3d model and python is a good language for a "simulation manager" script.
I was looking for an easy and efficient way to read result values.
According to what you say read the csv file directly is the best way. There are some libraries for that. I'll try this way.
Patch average:
at the interface 0D / 3D I've to calculate the velocity and pressure and insert the values in the 0D system .
I don't know if the functionObject I've written in the previous post is correct. I'll try.
I appreciate any advice that you can give me.
Old   February 14, 2014, 12:22
Assistant Moderator
Bernhard Gschaider
Patch average:
But the 1D-model will only use the OF-data as an input? Not feed back? Then reading the result files is IMHO the best way.
Concerning the FO: "expression" is not needed for patchAverage (all things in the simpleFunctionObjects-sublibrary work without parsers. They MAY have subclasses that do that)
Old   February 17, 2014, 10:25
Davide Pasini
Foreach timestep the python script reads the OF results and inserts the values to the 0D model.
After a timestep the 0D model returns the initial conditions of the 3D model.
I think this flow is correct.
Old   February 20, 2014, 17:46
Assistant Moderator
Bernhard Gschaider
"For each timestep" and "initial condition" somehow don't work for me (or are you talking about boundary conditions? That would be a feedback of the model)
Thread Tools
Trackbacks are On
how to calculate mass flow rate on patches and summation of that during the run? immortality OpenFOAM Post-Processing 82 November 25, 2014 14:16
DEFINE_ADJUST: How open and read file values (.prof or .txt) into one boundary rayolau Fluent UDF and Scheme Programming 0 April 25, 2013 07:01
Import field from CFX5 result file top OpenFOAM 2.1.1 konneym OpenFOAM Pre-Processing 0 March 5, 2013 14:20
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
Read values from previous timesteps vmlxb6 CFX 9 April 22, 2011 18:56
