-   -   Using shipFoam the tank slowly runs empty (http://www.cfd-online.com/Forums/openfoam-solving/129666-using-shipfoam-tank-slowly-runs-empty.html)
manoj_nav February 10, 2014 11:46
Hi all
I am new to OF and I am using shipFoam under OF1.6 to simulate flow around ship hull in calm water and with waves. But as the simulation progresses, the tank slowly empties. Please help me to identify the issue.
I have given following input to alpha, p and U under folder '0'.
Alpha :
FoamFile
version 2.0;
format ascii;
class volScalarField;
location "0";
object alpha;
dimensions [0 0 0 0 0 0 0];
internalField uniform 0;
boundaryField
Inlet
type fixedValue;
value uniform 1;
Outlet
type inletOutlet;
inletValue uniform 0;
value uniform 1;
Top
type inletOutlet;
value uniform 0;
sides
type symmetryPlane;
hull_wall
type zeroGradient;
p :
FoamFile
version 2.0;
format ascii;
location "0";
object pd;
dimensions [1 -1 -2 0 0 0 0];
boundaryField
Inlet
type zeroGradient;
Outlet
type zeroGradient;
Top
type totalPressure;
p0 uniform 0;
U U;
phi phi;
rho rho;
psi none;
gamma 0;
value uniform 0;
sides
type symmetryPlane;
hull_wall
type zeroGradient;
U:
FoamFile
version 2.0;
format ascii;
class volVectorField;
location "0";
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0.5 0 0);
boundaryField
Inlet
type surfaceWaveVelocity;
phi phi;
value uniform (0.5 0 0);
Outlet
type inletOutlet;
inletValue uniform (0 0 0);
Top
type pressureInletOutletVelocity;
sides
type symmetryPlane;
hull_wall
type movingWallVelocity;
value uniform (0 0 0);
Regards,
Manoj
