May 30, 2020, 17:08 |
Multiple zones when using splitMeshRegions
Rep Power: 6 |
Hello to all Foamers,
I will state my problem: I am creating a case where 2 solids in contact are transferring heat to the surrounding air. I am using OpenFOAM v1912. I generated the mesh with snappyHexMesh and I am happy with the end result. However, I am getting problems when I use the splitMeshRegion -cellZones utility. It creates domains not defined by me with zones having negative values. I do not know where do these domains came from and would like a methodology to solve this. Code:
0 0 air 1 1 solid1 2 2 solid2 3 -1 domain3 4 -1 domain4 5 -1 domain5 6 -1 domain6 7 -1 domain7 . . . Methodology 1: I first ran surfaceCheck to check if both solids where closed. The results showed that there was no problem with the stls. Then, I created the background mesh with blockMesh and attributed a cellZone to it via : Code:
blocks ( hex (0 1 2 3 4 5 6 7 ) air (40 40 40) simpleGrading (1 1 1) ); Code:
refinementSurfaces { solid1 { // Surface-wise min and max refinement level level (4 4); // Define cell and Face Zones faceZone solid1; cellZone solid1; cellZoneInside insidePoint; insidePoint (-3.021234 10.04124 -132.51234); } solid2 { // Surface-wise min and max refinement level level (3 3); // Define cell and Face Zones faceZone solid2; cellZone solid2; cellZoneInside insidePoint; insidePoint (-3.021234 5.04124 -132.51234); } } The mesh is Ok, but when I use the splitMeshRegions -cellZones I get the multiple domains which I referred to in the beginning of the post. CheckMesh result: Code:
Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology inlet 3600 3721 ok (non-closed singly connected) outlet 3600 3721 ok (non-closed singly connected) walls 14400 14640 ok (non-closed singly connected) Checking faceZone topology for multiply connected surfaces... FaceZone Faces Points Surface topology solid1 34731 40381 multiply connected (shared edge) solid2 167899 175310 multiply connected (shared edge) <<Writing 280 conflicting points to set nonManifoldPoints Checking basic cellZone addressing... CellZone Cells Points VolumeBoundingBox air 938384 1153598 0.9995443 (-0.5037818 -0.4477832 -0.6351975) (0.4962182 0.5522168 0.3648025) solid1 140552 182724 0.0003240833 (-0.0463241 -0.01032742 -0.2624402) (0.04019703 0.02055706 -0.002523096) solid2 242021 349657 0.0001315835 (-0.04803438 0.007296541 -0.2642762) (0.04047093 0.09695013 -0.006148401) Checking geometry... Overall domain bounding box (-0.5037818 -0.4477832 -0.6351975) (0.4962182 0.5522168 0.3648025) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (9.670993e-16 9.711741e-17 4.235526e-16) OK. Max cell openness = 3.987074e-16 OK. Max aspect ratio = 12.61511 OK. Minimum face area = 1.304291e-08. Maximum face area = 0.0002779737. Face area magnitudes OK. Min volume = 6.190595e-12. Max volume = 4.632872e-06. Total volume = 1. Cell volumes OK. Mesh non-orthogonality Max: 61.39361 average: 11.34664 Non-orthogonality check OK. Face pyramids OK. Max skewness = 1.485724 OK. Coupled point location match (average 0) OK. Mesh OK. End Code:
Time = 1 Solving for fluid region air DILUPBiCGStab: Solving for Ux, Initial residual = 1, Final residual = 0.0116219, No Iterations 1 DILUPBiCGStab: Solving for Uy, Initial residual = 1, Final residual = 0.001894981, No Iterations 1 DILUPBiCGStab: Solving for Uz, Initial residual = 1, Final residual = 0.0113973, No Iterations 1 DILUPBiCGStab: Solving for h, Initial residual = 1, Final residual = 0.0006057759, No Iterations 1 Min/max T:273 273.1336 #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in /lib/x86_64-linux-gnu/libc.so.6 #3 Foam::DICPreconditioner::calcReciprocalD(Foam::Field<double>&, Foam::lduMatrix const&) at ??:? #4 Foam::DICPreconditioner::DICPreconditioner(Foam::lduMatrix::solver const&, Foam::dictionary const&) at ??:? #5 Foam::lduMatrix::preconditioner::addsymMatrixConstructorToTable<Foam::DICPreconditioner>::New(Foam::lduMatrix::solver const&, Foam::dictionary const&) at ??:? #6 Foam::lduMatrix::preconditioner::New(Foam::lduMatrix::solver const&, Foam::dictionary const&) at ??:? #7 Foam::PCG::scalarSolve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #8 Foam::GAMGSolver::solveCoarsestLevel(Foam::Field<double>&, Foam::Field<double> const&) const at ??:? #9 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:? #10 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #11 Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:? #12 Foam::fvMatrix<double>::solveSegregatedOrCoupled(Foam::dictionary const&) at ??:? #13 Foam::fvMesh::solve(Foam::fvMatrix<double>&, Foam::dictionary const&) const at ??:? #14 Foam::fvMatrix<double>::solve() in ~/OpenFOAM/OpenFOAM-v1912/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionSimpleFoam #15 ? in ~/OpenFOAM/OpenFOAM-v1912/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionSimpleFoam #16 __libc_start_main in /lib/x86_64-linux-gnu/libc.so.6 #17 ? in ~/OpenFOAM/OpenFOAM-v1912/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionSimpleFoam Floating point exception (core dumped) Methodology 2: All of the setting used in the snappyHexMesh were the same except for the definition of the regions. Here, I did not define any region with blockMesh and everything with SHMdict as follows: Code:
locationsInMesh ( ((-3.021234 10.04124 -132.51234) solid1) ((-3.021234 5.04124 -132.51234) solid2) ((100.1234 0.1234 0.1234) air) ); Code:
Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology inlet 3600 3721 ok (non-closed singly connected) outlet 3600 3721 ok (non-closed singly connected) walls 14400 14640 ok (non-closed singly connected) solid1 645 1117 ok (non-closed singly connected) solid2 690 1188 ok (non-closed singly connected) Checking faceZone topology for multiply connected surfaces... FaceZone Faces Points Surface topology solid1_to_air 23995 25495 ok (non-closed singly connected) solid2_to_air 152673 156544 multiply connected (shared edge) solid2_to_solid1 24663 26057 ok (non-closed singly connected) <<Writing 190 conflicting points to set nonManifoldPoints Checking basic cellZone addressing... CellZone Cells Points VolumeBoundingBox solid2 242020 349664 131529.9 (-48.03443 7.322347 -264.2761) (40.46967 96.95013 -6.123892) solid1 140552 182706 324154.9 (-46.31507 -10.32614 -262.4393) (40.19727 20.53908 -2.522975) air 938067 1152245 9.995443e+08 (-503.7818 -447.7832 -635.1975) (496.2182 552.2168 364.8025) Checking geometry... Overall domain bounding box (-503.7818 -447.7832 -635.1975) (496.2182 552.2168 364.8025) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (7.70767e-16 -1.114579e-16 3.747821e-16) OK. Max cell openness = 5.113948e-16 OK. Max aspect ratio = 11.17296 OK. Minimum face area = 0.006413276. Maximum face area = 277.9738. Face area magnitudes OK. Min volume = 0.006188031. Max volume = 4632.874. Total volume = 1e+09. Cell volumes OK. Mesh non-orthogonality Max: 61.4087 average: 11.33247 Non-orthogonality check OK. Face pyramids OK. ***Max skewness = 17.17423, 68 highly skew faces detected which may impair the quality of the results <<Writing 68 skew faces to set skewFaces Coupled point location match (average 0) OK. Failed 1 mesh checks. End As anyone experienced something like this? Why does snappyHexMesh create these patches and why does the splitMeshRegions utility create the previously mentioned zones? Does anyone know of a methodology to go around this? Thanks! |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
Creatin macros for multiple data sets and assigning multiple zones | Skyler | Tecplot | 0 | January 24, 2019 12:24 |
[snappyHexMesh] Creating multiple multiple cell zones with snappyHexMesh - a newbie in deep water! | divergence | OpenFOAM Meshing & Mesh Conversion | 0 | January 23, 2019 04:17 |
Multiple Zones in Ansys CFX 14.5 | r.mojtaba | CFX | 3 | July 28, 2013 07:31 |
OpenFOAM static build on Cray XT5 | asaijo | OpenFOAM Installation | 9 | April 6, 2011 12:21 |
