February 14, 2014, 05:34 |
Residual Plotting Script
Philipp
Rep Power: 26 |
I made some handy script to plot residuals during runtime using gnuplot. It works with SIMPLE and PIMPLE, probably also with other solvers. First of all, you need to get the OpenFOAM terminal output into a file. This is done by starting OpenFoam with the ">log" command, such as: mpirun -np 4 pimpleFoam -parallel >log or just simple >log where "log" is the name of the file with the output. Now, create some new file "plotscript" in the same folder and copy this text into it: Code:
set logscale y set title "Residuals" set ylabel 'Residual' set xlabel 'Iteration' set key outside set grid nCorrectors=1 nNonOrthogonalCorrectors=3 nCont = nCorrectors nP = (nNonOrthogonalCorrectors+1)*nCont nPSkip = nP-1 nContSkip = nCont-1 plot "< cat log | grep 'Solving for Ux' | cut -d' ' -f9 | tr -d ','" title 'Ux' with linespoints,\ "< cat log | grep 'Solving for Uy' | cut -d' ' -f9 | tr -d ','" title 'Uy' with linespoints,\ "< cat log | grep 'Solving for Uz' | cut -d' ' -f9 | tr -d ','" title 'Uz' with linespoints,\ "< cat log | grep 'Solving for k' | cut -d' ' -f9 | tr -d ','" title 'k' with linespoints,\ "< cat log | grep 'Solving for epsilon' | cut -d' ' -f9 | tr -d ','" title 'epsilon' with linespoints,\ "< cat log | grep 'time step continuity errors :' | cut -d' ' -f9 | tr -d ','" every nCont::nContSkip title 'continuity' with linespoints,\ "< cat log | grep 'Solving for p' | cut -d' ' -f9 | tr -d ','" every nP::nPSkip title 'p' with linespoints lc 8 pause 1 xmax = GPVAL_DATA_X_MAX+2 xmin = xmax-40 set xrange [xmin:xmax] reread You need to adapt the upper two numbers nCorrectors and nNonOrthogonalCorrectors to your case, because they need to delete all the intermediate steps of the pressure solving. Also, for long runs I implemented the stuff between "pause 1" and "reread" which will show only the last 40 steps. You can change it to any number or switch off completely by putting a "#" at the beginning of each line. Of course, change "epsilon" to "omega" if you use some k-omega turbulence model. Have fun, Philipp.
The skeleton ran out of shampoo in the shower. |
February 14, 2014, 10:42 |
Joachim Herb
Rep Power: 21 |
Using your code I get the following error message:
"Residuals", line 26: undefined variable: GPVAL_DATA_X_MAX > gnuplot --version gnuplot 4.2 patchlevel 3 |
February 14, 2014, 11:09 |
Philipp
Rep Power: 26 |
Hi Joachim,
I got two ideas: i) Your version is too old, I use 4.6 ii) The initial "plot" command did not work. Variable "GPVAL_DATA_X_MAX" is created by gnuplot after a plot was successfully done. Thus, if the lines before didn't work for some reason, also the GPVAL_DATA_X_MAX variable is not known. Does the script run without these three lines?
February 14, 2014, 18:40 |
Joachim Herb
Rep Power: 21 |
If I remove the three lines between pause and reread the script works.
February 17, 2014, 05:27 |
Philipp
Rep Power: 26 |
You can start a gnuplot terminal gnuplot Then just do some random plot plot 1 and let gnuplot show all the created variables show variables all Does it show the GPVAL_DATA_X_MAX?
February 17, 2014, 05:45 |
#6 | |
Joachim Herb
Rep Power: 21 |
Actually, no: Code:
gnuplot> show variables all All available variables: pi = 3.14159265358979 NaN = NaN GNUTERM = "x11" GPVAL_TERM = "x11" GPVAL_TERMOPTIONS = "" GPVAL_OUTPUT = "" GPVAL_VERSION = 4.2 GPVAL_PATCHLEVEL = "3 " GPVAL_COMPILE_OPTIONS = "-READLINE +LIBREADLINE +HISTORY +BACKWARDS_COMPATIBILITY +BINARY_DATA \n+GD_PNG +GD_JPEG +GD_TTF +GD_GIF +ANIMATION \n+NOCWDRC +X11 +X11_POLYGON +MULTIBYTE +USE_MOUSE +GNUGRAPH +HIDDEN3D_QUADTREE \n+DATASTRINGS +HISTOGRAMS +OBJECTS +STRINGVARS +MACROS +THIN_SPLINES +IMAGE \n" GPVAL_X_MIN = -10.0 GPVAL_X_MAX = 10.0 GPVAL_X_REVERSE = 0 GPVAL_X_LOG = 0.0 GPVAL_Y_MIN = 0.99 GPVAL_Y_MAX = 1.01 GPVAL_Y_REVERSE = 0 GPVAL_Y_LOG = 0.0 GPVAL_X2_MIN = -10.0 GPVAL_X2_MAX = 10.0 GPVAL_X2_REVERSE = 0 GPVAL_X2_LOG = 0.0 GPVAL_Y2_MIN = 0.99 GPVAL_Y2_MAX = 1.01 GPVAL_Y2_REVERSE = 0 GPVAL_Y2_LOG = 0.0 GPVAL_Z_MIN = -10.0 GPVAL_Z_MAX = 10.0 GPVAL_Z_REVERSE = 0 GPVAL_Z_LOG = 0.0 GPVAL_CB_MIN = -8.98846567431158e+307 GPVAL_CB_MAX = 8.98846567431158e+307 GPVAL_CB_REVERSE = 0 GPVAL_CB_LOG = 0.0 GPVAL_T_MIN = -5.0 GPVAL_T_MAX = 5.0 GPVAL_T_REVERSE = 0 GPVAL_T_LOG = 0.0 GPVAL_U_MIN = -10.0 GPVAL_U_MAX = 10.0 GPVAL_U_REVERSE = 0 GPVAL_U_LOG = 0.0 GPVAL_V_MIN = -10.0 GPVAL_V_MAX = 10.0 GPVAL_V_REVERSE = 0 GPVAL_V_LOG = 0.0 |
February 17, 2014, 05:54 |
Joachim Herb
Rep Power: 21 |
Ok, with the current version of gnuplot (4.6.4) it is working.
Thank your for the script. |
February 17, 2014, 05:56 |
Philipp
Rep Power: 26 |
You could have changed the GPVAL_DATA_X_MAX to GPVAL_X_MAX?
Seems like they renamed that in the newer versions...
September 12, 2016, 03:43 |
How to export image of finally converged solution and how to close gnuplot
Sing
Rep Power: 10 |
Hello Phillipp,
First of all thank you very much for posting this script. I have used this script for a simulation which I do manually and its working fine. Problem arose when I automated the process of simulation using shell script. In the script I have used the following code. Code:
mpirun -np 4 buoyantBoussinesqSimpleFoam -parallel >log gnuplot residue reconstructPar Code:
set logscale y set title "Residuals" set ylabel 'Residual' set xlabel 'Iteration' set term postscript set output "printme.ps" plot "< cat log | grep 'Solving for Ux' | cut -d' ' -f9 | tr -d ','" title 'Ux' with lines,\ "< cat log | grep 'Solving for Uy' | cut -d' ' -f9 | tr -d ','" title 'Uy' with lines,\ "< cat log | grep 'Solving for Uz' | cut -d' ' -f9 | tr -d ','" title 'Uz' with lines,\ "< cat log | grep 'Solving for T' | cut -d' ' -f9 | tr -d ','" title 'T' with lines,\ "< cat log | grep 'Solving for p_rgh' | cut -d' ' -f9 | tr -d ','" title 'p_rgh' with lines,\ "< cat log | grep 'Solving for epsilon' | cut -d' ' -f9 | tr -d ','" title 'epsilon' with lines,\ "< cat log | grep 'Solving for k' | cut -d' ' -f9 | tr -d ','" title 'k' with lines pause 1 reread Any help would be greatly appreciated. Thanks and regards, Singh. |
September 13, 2016, 03:12 |
Philipp
Rep Power: 26 |
Hi Singh,
The line "pause 1" and "reread" let the gnuplot script restart itself again and again. That's why gnuplot seems to freeze. Maybe you need to find a better way. The problem is, when you just delete them, gnuplot plots and gets closed very fast, so also the plotting window gets closed. You won't be able to see the plot. There is probably a way to do what you want, but I never did that. Philipp.
September 14, 2016, 01:42 |
Found a way!!
#11 | |
Sing
Rep Power: 10 |
Thank you very much for the reply. I have found a way to close the gnuplot which is in background. I am not sure whether this is the right way to do but it worked for me. What I have done is that I have used the following commands in my shell script: Code:
mpirun -np 4 buoyantBoussinesqSimpleFoam -parallel >log & sleep 10s gnuplot residue & a=0 while [ a=0 ] do FILE=log # How many seconds before file is deemed "older" OLDTIME=5 #Get current and file times CURTIME=$(date +%s) FILETIME=$(stat $FILE -c %Y) TIMEDIFF=$(expr $CURTIME - $FILETIME) # Check if file older if [ $TIMEDIFF -gt $OLDTIME ]; then sleep 5s python plotEnd.py a=1 break fi done Code:
import sys import os os.system("ps -aux|grep 1016914 > log_ID") with open('log_ID','r') as LM: for line in LM: A = line.split() if len(A)>=2: #print A[10] if A[10]=="gnuplot": z = A[1]; #print (z) if A[10]=="evince": y = A[1]; os.system("kill -9 " + z) os.system("time.sleep(20)") os.system("kill -9 " + y) And this worked for me, hope it will be helpful to some other newbie like me. Thanks and regards, Prateek Singh. |
June 29, 2022, 02:48 |
#12 |
Rep Power: 3 |
starting with scripts from this page, and modifying things a bit I found this works and is quickly tuneable as the number of pressure iterations per timestep changes (15 is bad... I know...... but it works for me
set logscale y set title "Residuals" set ylabel 'Residual' set xlabel 'Iteration' set grid plot "< cat log.pimpleFoam | grep 'Solving for Urelx' | cut -d' ' -f9 | tr -d ','" title 'Ux' with lines,\ "< cat log.pimpleFoam | grep 'Solving for Urely' | cut -d' ' -f9 | tr -d ','" title 'Uy' with lines,\ "< cat log.pimpleFoam | grep 'Solving for Urelz' | cut -d' ' -f9 | tr -d ','" title 'Uz' with lines,\ "< cat log.pimpleFoam | grep 'Solving for epsilon' | cut -d' ' -f9 | tr -d ','" title 'Uz' with lines,\ "< cat log.pimpleFoam | grep 'Solving for k' | cut -d' ' -f9 | tr -d ','" title 'k' with lines,\ "< cat log.pimpleFoam | grep 'Solving for p' | cut -d' ' -f9 | sed -n '0~15p' | tr -d ','" title 'p' with lines pause 20 reread |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 14:12 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 14:58 |
pimpleFoam: turbulence->correct(); is not executed when using residualControl | hfs | OpenFOAM Running, Solving & CFD | 3 | October 29, 2013 09:35 |
calculation stops after few time steps | sivakumar | OpenFOAM Running, Solving & CFD | 7 | March 17, 2013 07:37 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 06:24 |
