OpenFOAM crashes using high resolution grid at wall |
February 17, 2014, 09:44 |
#1 | |
Dear all,
I am really new to OpenFOAM, and after going through some of the tutorials I found the simpleFoam/turbineSiting tutorial which helped me to create a simulation with an atmospheric boundary layer (ABL). For my own test simulation I wanna start with an empty domain with an ABL just going through it. This works fine for an uniform mesh of 0.1m in a 1.6x1.8x12m domain. For my further studies it is necessary to have a high mesh resolution of the boundary layer at the bottom of the domain. So, I tried to put the node of the first cell at the bottom at about y+ = 30 which should be above the buffer layer to use wall functions for the viscous layer at the wall. In my case I considered the freestream velocity as 6m/s, and the boundary length as 1.2m which gave me - using the cfd-online tool - a y+=30 wall distance of 0.0016m. However, when I make the mesh this dense at the bottom of my domain the simulation crashes in OpenFoam. Here is the errorcode if that helps: Quote:
nutkWallfunction for the walls kqRWallFunction for k epsilonWallFunction for eps no-slip condition for U zeroGradient for p I also changed the inlet conditions of the ABL using Uref= 4 m/s, Href = 0,25m. I am thankful for any comments regarding my thoughts about the simulations or hints why my denser mesh doesn't work. |
how to understand high resolution scheme and high order scheme | iilw1314 | Main CFD Forum | 7 | April 12, 2022 12:29 |
Enhanced Wall Treatment | paduchev | FLUENT | 24 | January 8, 2018 11:55 |
Grid deformation for high aspect ratio grids | praveen | SU2 Shape Design | 5 | February 15, 2013 19:50 |
Grid refinement with wall functions | Mark Render | Main CFD Forum | 8 | May 2, 2000 07:09 |
