Home > Forums > OpenFOAM Running, Solving & CFD
buoyantSimpleFoam -- circuitBoardCooling --- velocity iteration is gone?
Old   February 18, 2014, 06:39
Default buoyantSimpleFoam -- circuitBoardCooling --- velocity iteration is gone?
Cong
wc34071209 is on a distinguished road
Hello Foamers,
When I was doing the circuitBoardingCooling tutorial, I noticed in the output log file that velocity U iterations are gone.
I am wondering what is behind this ?
Can anybody tell me something about it?
Also in my own case, after one iteration, it suddenly blowed up. Can anybody know how to rescue it?
Starting time loop
Time = 1
smoothSolver: Solving for h, Initial residual = 0.999999760734241, Final residual = 0.0739844526791796, No Iterations 2
GAMG: Solving for p_rgh, Initial residual = 0.670879701157613, Final residual = 0.00515467031237578, No Iterations 10
GAMG: Solving for p_rgh, Initial residual = 0.894001123688478, Final residual = 0.00856064876150383, No Iterations 4
time step continuity errors : sum local = 0.239582634384328, global = -0.00338366580637759, cumulative = -0.00338366580637759
rho max/min : 1.20719519360923 1.14427087541347
smoothSolver: Solving for omega, Initial residual = 0.955316700148856, Final residual = 0.0634787254801369, No Iterations 4
smoothSolver: Solving for k, Initial residual = 0.999999999999505, Final residual = 0.00103042674222991, No Iterations 1
ExecutionTime = 9.29 s ClockTime = 9 s
Time = 2
smoothSolver: Solving for h, Initial residual = 0.999325490078903, Final residual = 0.0244002703888714, No Iterations 2
GAMG: Solving for p_rgh, Initial residual = 0.988285478738131, Final residual = 3.34337551006217e+61, No Iterations 25
GAMG: Solving for p_rgh, Initial residual = 0.992397990431178, Final residual = 2.4147324455547e+64, No Iterations 25
time step continuity errors : sum local = 5.91744896417765e+128, global = -1.05316590213318e+126, cumulative = -1.05316590213318e+126
rho max/min : 602.133880892008 -142.544096582093
smoothSolver: Solving for omega, Initial residual = 1, Final residual = 0.0241920534931177, No Iterations 2
bounding omega, min: -7.93695792121957e+131 max: 7.45791093353902e+134 average: 4.42408455315227e+129
smoothSolver: Solving for k, Initial residual = 0.863355892782795, Final residual = 0.00502742854378505, No Iterations 1
bounding k, min: -0.0057214152428458 max: 0.00532875391960471 average: 0.000455092432860109
ExecutionTime = 19.81 s ClockTime = 19 s
Time = 3
[0] #0 [1] #0 [2] #0 [3] #0 Foam::error:rintStack(Foam::Ostream&)Foam::error :rintStack(Foam::Ostream&)Foam::error:rintStac k(Foam::Ostream&)Foam::error:rintStack(Foam::Ost ream&) at ??:?
[2] #1 Foam::sigFpe::sigHandler(int) at ??:?
[0] #1 Foam::sigFpe::sigHandler(int) at ??:?
[1] #1 Foam::sigFpe::sigHandler(int) at ??:?
[3] #1 Foam::sigFpe::sigHandler(int) at ??:?
[0] #2 at ??:?
[3] #2 at ??:?
[2] #2 at ??:?
[1] #2 in "/lib/x86_64-linux-gnu/libc.so.6" in "/lib/x86_64-linux-gnu/libc.so.6"
[0] #3
[3] #3 Foam::multiply(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&)Foam::multiply(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/lib/x86_64-linux-gnu/libc.so.6"
[1] #3 Foam::multiply(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) in "/lib/x86_64-linux-gnu/libc.so.6"
[2] #3 Foam::multiply(Foam::Field<double>&, Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
[1] #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator*<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
[2] #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator*<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
[3] #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator*<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
[0] #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam:perator*<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<doub le, Foam::fvPatchField, Foam::volMesh> > const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
[2] #5 at ??:?
[3] #5 Foam::fv::boundedConvectionScheme<double>::fvcDiv( Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const at Foam::fv::boundedConvectionScheme<double>::fvcDiv( Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const??:?
[0] #5 Foam::fv::boundedConvectionScheme<double>::fvcDiv( Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) const at ??:?
wc34071209 is offline   Reply With Quote
Old   February 18, 2014, 06:52
Alexey Matveichev
alexeym will become famous soon enoughalexeym will become famous soon enough
If you take a look at fvSolution there is subdict SIMPLE
SIMPLE
    momentumPredictor no;
Cause there is no momentum predictor step there is no lines in the log for U equation. If you change momentuPredictor to yes, velocity iterations will return.
alexeym is offline   Reply With Quote
Old   February 18, 2014, 07:00
Cong
Thanks a lot.
Now I want to know under what condition we don't need momentum prediction and under what conditions we need.
Old   February 18, 2014, 08:10
Alexey Matveichev
There's Google (or the forum search), you know...
One of the explanations:
When to set momentumPredictor to Yes
Thread Tools
Trackbacks are On
LES and TKE calculations MST Main CFD Forum 3 May 30, 2016 06:26
Radial velocity and tangential velocity on centrifugal fan, johnnyp FLUENT 2 May 24, 2013 07:10
how to compute relative velocity from absolute? spk Main CFD Forum 3 July 9, 2010 08:42
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
Velocity in Porous medium : HELP! HELP! HELP! Kali Sanjay Phoenics 0 November 6, 2006 07:10
