February 19, 2014, 06:02 |
3D symmetric dynamic mesh not converging
Devayan Bir
Rep Power: 12 |
Can any suggest a solution for this error. I am trying to simulate a flow around a ship and my mesh is symmetric. The latest version OF 2.3.0 which has been updated for ship hydrodynamics is giving me this error when i try to do setFields. I did not encounter this issue in the previous versions. Symmetry plane 'SYM' is not planar. At local face at (0.594458857082 1.1980965844e-09 -0.938176870404) the normal (2.14036769809e-07 -1 2.06496503342e-07) differs from the average normal (-7.90999860659e-11 -1 8.52793799709e-11) by 8.84511990759e-14 Either split the patch into planar parts or use the symmetry patch type From function symmetryPlanePolyPatch::n() in file meshes/polyMesh/polyPatches/constraint/symmetryPlane/symmetryPlanePolyPatch.C at line 64. |
December 9, 2014, 03:25 |
Solution found?
Lilly
Rep Power: 11 |
Hey,
did you find a working solution? Best regards EDIT: I changed the BC from "symmetryPlane" to simply "symmetry" and it worked. However, I do not find documentation regarding the difference between the two BC's. Last edited by 5tern; December 10, 2014 at 05:32. |
May 20, 2015, 04:17 |
Rep Power: 14 |
Same problem here, setting the boundary to symmetry solves the issue, but I can't find documentation either.
October 14, 2015, 02:56 |
This might help
Vaibhav
Rep Power: 11 |
http://openfoam.org/version2.3.0/numerics.php
They have mentioned this in the release notes for version 2.3. However, I have the same problems. I have set of patches in the same plane which I want to make a symmetry plane but I cannot use the symmetryPlane condition. Instead I have to use "symmetry" condition. I do not understand since my plane is basically perpendicular to Z axis (z = constant) and all the points have the same Z coordinate. I am also a bit new to OpenFOAM so it would be good if anyone with more experience can weigh in on it. |
pls help. mesh collapsed with dynamic mesh. | wlt_1985 | FLUENT | 2 | May 7, 2020 10:42 |
Dynamic mesh is not getting updated. | cardio | FLUENT | 1 | May 20, 2014 08:41 |
Dynamic Mesh "Shadow Wall" | thezack | FLUENT | 0 | June 4, 2013 22:09 |
dynamic mesh for drop interface | IndrajitW | FLUENT | 0 | March 30, 2013 08:03 |
dynamic mesh on a hexa grid | Manoj Kumar | FLUENT | 0 | August 21, 2007 07:41 |
