MULES error
Old   February 21, 2014, 09:02
Default MULES error
Luis Miguel
luigi21 is on a distinguished road
Hello Foamers....
I'm running in parallel and I get an error in the MULES, I've read this is because of a bad decomposition in the geometric domain but I'm not sure if this error is due to the way I've created my mesh taking into account that my checkMesh runs well; check this error out:
Foam::error:rintStack(Foam::Ostream&)Foam::error :rintStack(Foam::Ostream&) at ??:?
[0] #1 Foam::sigFpe::sigHandler(int) at ??:?
[1] #1 Foam::sigFpe::sigHandler(int) at ??:?
[1] #2 at ??:?
[0] #2 in "/lib/x86_64-linux-gnu/libc.so.6"
[0] #3 void Foam::MULES::limiter<Foam::geometricOneField, Foam::zeroField, Foam::zeroField>(Foam::Field<double>&, Foam::geometricOneField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::zeroField const&, Foam::zeroField const&, double, double, int) in "/lib/x86_64-linux-gnu/libc.so.6"
[1] #3 void Foam::MULES::limiter<Foam::geometricOneField, Foam::zeroField, Foam::zeroField>(Foam::Field<double>&, Foam::geometricOneField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::zeroField const&, Foam::zeroField const&, double, double, int) at ??:?
[0] #4 void Foam::MULES::limit<Foam::geometricOneField, Foam::zeroField, Foam::zeroField>(Foam::geometricOneField const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh>&, Foam::zeroField const&, Foam::zeroField const&, double, double, int, bool) at ??:?
What do you think of that? now I'm running without use parallel run and the simulation stops in the second 3.16 without any error, I mean still runs but it's not making any computation at all or if it's doing something it should be really really slow operations. thanks for your help
Best regards.
luigi21 is offline   Reply With Quote
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
c++ libraries and solver compiling vaina74 OpenFOAM Installation 13 February 3, 2012 17:43
[OpenFOAM] Saving ParaFoam views and case sail ParaView 9 November 25, 2011 15:46
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
