Home > Forums > OpenFOAM Running, Solving & CFD
Help!!! Cumulative error too High
Old   February 21, 2014, 18:49
Default Help!!! Cumulative error too High
ArathoN
ArathoN is on a distinguished road
Please can someone help me here? I'm simulating the backward facing step with and without the fully developed flow at inlet. My problem is i'm getting High value of the cumulative continuity errors, especially for the case with the fully developed flow. As a consequence the fields data are really strange see my post here.
In case of the fully developed flow i used the "setdiscreteFields" to map the inlet BCs. I'll upload my case,please take a look at it and see if you can find what i'm doing wrong, i tried everything and changed almost everything with no success.
I changed also the mesh, varied the yplus value, the grid spacing (uniform and non uniform) used different programs to create the mesh but all in vain.
here the zip with the case:
https://www.dropbox.com/s/76zz543hb5p3808/BFS.zip
Hoping someone would help me this time.
ArathoN is offline   Reply With Quote
Old   February 22, 2014, 17:25
ArathoN
I tried to find out the culprit of the high cumulative error and the weird behavior of the field around the step, I simplified the mesh and i've considered a uniform mesh with the fully developed flow imposed at the inlet and the residual have a really strange behavior and i don't know what is the cause of it i started with the mesh at yplus 30 then i started to refine (x4) but i observed the same pattern.
I uploaded an image with the plot of the residual done with pyFoam.
P.S how can i save the plots done by pyFoam?
Old   February 23, 2014, 04:44
ArathoN
I increased the cell number up to 400000 from around 12000, but th residuals have the save pattern. Now i'll try to change the initial condition and see if the problem lies there. Can the schemes or fvsolution settings be the reason of this?
Old   February 24, 2014, 09:31
Cong
wc34071209 is on a distinguished road
I am faced with almost the same problem and I don't know why.
wc34071209 is offline   Reply With Quote
Old   February 27, 2014, 11:18
ArathoN
I've gonna do more tests, but i narrowed it down to teh k/omega/epsilon initial values or the schemes used in fvchemes.
I decided to simplify the mesh using an uniform with the same spacing in the x and y direction, then i increased the cell points and simulated it (up to about 500000 cells) and all of them had the same behavior of the residuals. The residuals tend to go down at each iteration then they explode when they are around e-5, they manifest an oscillatory behavior with a large amplitude and i'm still trying to find out the root of the problem, for sure the initial value of the velocity (being a fully developed flow or not) ans the mesh aren't the cause of it.
Old   March 4, 2014, 13:07
ArathoN
I refined the mesh, changed the geometry and considered different types of BCs but i couldn't trace the root of the problem. With paraFoam i can't see the vortex (with the streamline tool) and the residual after some time will go crazy. Please can someone help me here.
Thread Tools
Trackbacks are On
How to write k and epsilon before the abnormal end xiuying OpenFOAM Running, Solving & CFD 8 August 27, 2013 15:33
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
