timevaryingfixedgradient Boundary condition
Old   June 5, 2013, 01:04
Default timevaryingfixedgradient Boundary condition
Nitin
Nitin Minocha is on a distinguished road
Hello all
I am working on the problem of Natural Convection as a part of my PhD. I am using Openfoam 2.2 and using buoyantBoussinesqPimpleFoam as a solver. I want to give time varying fixedGradient as a boundary condition in T file in 0 directory. Previously i used timevaryingUniformFixedValue successfully in Openfoam 1.6 but there is no such boundary condition available in Openfoam 2.2. I had gone through the several posts available in Openforum. I tried by giving my time varying fixed gradient data in the form of table in T directory itself but it doesn't work.
Please help.[/FONT]
Nitin Minocha is offline   Reply With Quote
Old   June 5, 2013, 01:28
Nima Samkhaniani
nimasam is on a distinguished road
if you want not to coding, you can easily use third party swak4Foam (groovyBC utility)
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   June 5, 2013, 06:30
Nitin
Thanks Nimasam for a quick reply.
I have seen utility of groovyBC as u said but what i learnt from that it's required time dependent expression of gradient. There is no option of reading a file having values containing time and gradient. I have a separate file containing time and gradient values. I am enclosing that file.
Please have a look.
Old   June 5, 2013, 07:48
Nima Samkhaniani
search in forum about reading file , i saw several times how to read values from a file, in groovyBC there is an option look at table which can do similar work
Old   June 13, 2013, 05:09
Nitin
Hi Nimasam
Thanks for your reply.
I downloaded, Swak4Foam and tried to install it by using wmake all. I also did appropriate changes in the control dict file but when i run my case, an error is coming that this groovyBC boundary condition is not existing.
Am i not installing it correctly?
Old   June 13, 2013, 05:25
Nima Samkhaniani
if you install it correctly, you should find groovyBC lib file in following address
/home/user/OpenFOAM/user-x.x.0/platforms/linuxGccDPOpt/lib
x is openfoam version
user is your username
Old   June 13, 2013, 05:29
Nitin
Hi Nimasam
It's not there. So what can i do. I already tried 3 times to install it.
Is there any other command apart from wmake all to install it.
Old   February 22, 2014, 05:15
Default Similar issue
Srivathsan N
Sherlock_1812 is on a distinguished road
Hi Nitin,
I am also having the same issue as yours. I have time and gradient values as a data file and am looking to use a timeVaryingFixedGradientValue type of boundary condition. However in my case, I'm worried about the linear interpolation of time values between two data entries since the variation in my case is far from linear.
Have you been able to find a way to solve this issue?
Regards,
Srivaths
Sherlock_1812 is offline   Reply With Quote
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Radiation interface hinca CFX 15 January 26, 2014 17:11
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
Setting outlet Pressure boundary condition using CAFFA code Mukund Pondkule Main CFD Forum 0 March 16, 2011 03:23
How exactly the "pressure outlet" bdry condition compute properties on the boundary? yating9901 FLUENT 3 June 28, 2010 12:26
