coefficient of power-Law viscosity Model in OpenFOAM
Hello foamers
I have searched a lot but I was not able to find any proper explanation about coefficient of power-Law viscosity Model. I have used online curve fitting tools to determine constant coefficients in power-Law viscosity model based on my experimental data. These values are obtained for k and n: k = 0.0102 [Pa.s^(n)] n = 0.46 Now when it comes to OpenFOAM, it uses kinematic viscosity and after reading source code of power-Law viscosity model, I have found out that k has the same dimension as nu. I have divided my k value by rho and that gives me: k = 7.293e-6 However, when I use this value for k the solution diverges quickly. I have seen a few tutorials in which k has a very large magnitude like 2500. Am I missing something here? maybe I did not understand the model properly. best wishes regards |
Hello Daniel,
Were you able to find a good explanantion for the power law model. I am also a little confused as to why k value is taken so large in some cases. If i take k value small, the solution is not converging. Please help!! |
Hi friends,
Have you found a solution for this problem that you can share with me? I have the same problem too... Cheers, FS |
Dear friends,
I have the same problem as you. Can someone post an explanation for this problem, plz? Thank you very much!! |
Same problem here. When I divide by density I get very high velocities...
I had this problem some time back. Someone suggested to initiate the flow with constant viscosity. The k value is supposed to be large (if i remember correctly). So yeah, i ran a few time steps with constant viscosity and then switched to power law model and that allowed the simulation to run smoothly. Try that! |
Hi
was anyone able to find the explanation of the units for k in openfoam? From this thread http://www.cfd-online.com/Forums/ope...del-blood.html i understand that openfoam multiples strain rate by one sec, so k does not have n in its power but how to eliminate sec from SI units. I get the values of k experimentally in pa.s^n. I dont know how to incorporate this into openfoam Thanks |
