Home > Forums > OpenFOAM Running, Solving & CFD
Help~~problems in running in parallel
Old   February 23, 2014, 22:45
Default Help~~problems in running in parallel
liyu
ahliyu is on a distinguished road
hello,
I am new to openfoam, and i am using the solver " icoUncoupledKinematicParcelFoam".
i want to run the tutorial of hopper in parallel with 4 processors on my computer.
i did not change anything of the decomposeParDic file, and the step of " decomposePar" worked well.
then, when i ran " mpirun -np 4 icoUncoupledKinematicParcelFoam -parallel ", there were problems.
Sorry! You were supposed to get help about:
find-available:not-valid
But I couldn't open the help file:
/home/inet107/OpenFOAM/ThirdParty-2.2.2/platforms/linux64Gcc/openmpi-1.6.3/share/openmpi/help-mca-base.txt: No such file or directory. Sorry!
[inet107-Precision-T7610:04118] *** Process received signal ***
[inet107-Precision-T7610:04118] Signal: Segmentation fault (11)
[inet107-Precision-T7610:04118] Signal code: Address not mapped (1)
[inet107-Precision-T7610:04118] Failing at address: 0x28
[inet107-Precision-T7610:04118] [ 0] /lib/x86_64-linux-gnu/libpthread.so.0(+0xfcb0) [0x7f419805ecb0]
[inet107-Precision-T7610:04118] [ 1] /usr/lib/libopen-pal.so.0(mca_base_select+0x108) [0x7f419828e518]
[inet107-Precision-T7610:04118] [ 2] /usr/lib/libopen-pal.so.0(opal_crs_base_select+0x7e) [0x7f41982a090e]
[inet107-Precision-T7610:04118] [ 3] /usr/lib/libopen-pal.so.0(opal_cr_init+0x31e) [0x7f419827f0ee]
[inet107-Precision-T7610:04118] [ 4] /usr/lib/libopen-pal.so.0(opal_init+0x159) [0x7f419827ea59]
[inet107-Precision-T7610:04118] [ 5] /usr/lib/libopen-rte.so.0(orte_init+0x4d) [0x7f41984d0a0d]
[inet107-Precision-T7610:04118] [ 6] mpirun() [0x402fe5]
[inet107-Precision-T7610:04118] [ 7] mpirun() [0x402b34]
[inet107-Precision-T7610:04118] [ 8] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xed) [0x7f4197cb176d]
[inet107-Precision-T7610:04118] [ 9] mpirun() [0x402a59]
[inet107-Precision-T7610:04118] *** End of error message ***
any help will be appreciated! ! thx
ahliyu is offline   Reply With Quote
Old   February 25, 2014, 21:23
liyu
is there anyone that can help me ?
Old   February 27, 2014, 20:34
Smile
liyu
haha, i finally solved this problem.
after the installation, you should find the bashrc file in etc/. then change the "openmpi" to "SYSTEMOPENMPI" at the 82 line.
Thread Tools
Trackbacks are On
running OpenFoam in parallel vishwa OpenFOAM Running, Solving & CFD 22 August 2, 2015 08:53
problem in running parallel: ./Allrun: 62: shift: can't shift that many adambarfi OpenFOAM Running, Solving & CFD 10 May 11, 2015 09:31
Problems running in parallel - missing controlDict Argen OpenFOAM Running, Solving & CFD 4 June 7, 2012 03:50
error while running in parallel using openmpi on local mc 6 processors suryawanshi_nitin OpenFOAM 5 May 21, 2012 14:13
Running mapFields with Parallel Source and Parallel Target RDanks OpenFOAM Mesh Utilities 2 June 6, 2011 07:56
