compressibleMultiphaseInterFoam with fvOptions Mass Source |
May 5, 2023, 03:35 |
Rep Power: 14 |
i am struggeling to add some material via fvOptions. Did anyone here manage to add mass e.g. over a cellZone? Thanks for helping me on that one. Br Christian |
May 5, 2023, 05:10 |
Paul Palladium
Rep Power: 10 |
Not sure to understand what you are trying to accomplish. You would like to simulate phase change ?
May 5, 2023, 05:11 |
Rep Power: 14 |
May 11, 2023, 08:17 |
Paul Palladium
Rep Power: 10 |
You want to have a "boundary condition" on a certain point on your mesh for defining velocity, alpha, temperature etc.. ?
I dont think it's possible to do that on OpenFOAM. fvOptions class allows you to have source terms. For Momentum equation you will be able to define an acceleration source but this is not what you want to do. For energy it will be power source and so on. |
May 11, 2023, 10:43 |
Rep Power: 14 |
Hi
thanks for the replay. I found code like this --> Mass source sounds like what i want to do. /*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 7 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object fvOptions; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // injector1 { timeStart 0.1; duration 5; selectionMode points; points ( (0.075 0.2 0.05) ); } options { massSource1 { type scalarSemiImplicitSource; $injector1; volumeMode absolute; injectionRateSuSp { thermo:rho.air (1e-3 0); // kg/s } } momentumSource1 { type vectorSemiImplicitSource; $injector1; volumeMode absolute; injectionRateSuSp { U.air ((0 -1e-2 0) 0); // kg*m/s^2 } } energySource1 { type scalarSemiImplicitSource; $injector1; volumeMode absolute; injectionRateSuSp { e.air (500 0); // kg*m^2/s^3 } } } // ************************************************** *********************** // |
June 12, 2023, 21:26 |
FOAMraj
Rep Power: 5 |
Hello, for this you have to mention the region in the topoSet and introduce the source term in fvOption mentioning the same region you mentioned in the topoSet.
[OpenFOAM.org] Error creating ParaView-4.1.0 OpenFOAM 2.3.0 | tlcoons | OpenFOAM Installation | 13 | April 20, 2016 17:34 |
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error | FerdiFuchs | OpenFOAM Community Contributions | 27 | April 16, 2014 15:14 |
"parabolicVelocity" in OpenFoam 2.1.0 ? | sawyer86 | OpenFOAM Running, Solving & CFD | 21 | February 7, 2012 11:44 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
