Solvers working with Cyclic BC
Old   July 16, 2013, 06:25
Default Solvers working with Cyclic BC
Mohammad
mohammad81 is on a distinguished road
Hi dear Foamers;
Do you know which solvers work well with Cyclic BC?
Through what I read through the forum, I think simpleFoam does not work with Cyclic.
ChannelFoam did work with it, but in OF2.2.1, it is removed.
Does pimpleFoam (which now includes channelFoam) can handle Cyclic?
If yes, what shall I do for laminar flow? I think pimple is for turbulent.
Thanks so much.
mohammad81 is offline   Reply With Quote
Old   August 22, 2013, 14:39
Shawn Fotovati
sfotovati is on a distinguished road
As far as I have seen, pimpleFoam and interFoam are ok with cyclic BC. However, I cannot maintain the velocity inside the domain.
Do you know how to avoid the velocity between cyclic BC's from slowing down to zero?
sfotovati is offline   Reply With Quote
Old   August 22, 2013, 14:44
Shawn Fotovati
Also in pimpleFoam, got to constant directory and change the turbulent properties from LES... to laminar, this turns the LES off.
Old   December 9, 2013, 15:45
yanxiang is on a distinguished road
Hi Shawn,
Did you solve this problem already? I am facing exactly the same issue.
Thanks,
Yanxiang
yanxiang is offline   Reply With Quote
Old   February 26, 2014, 08:10
Default LES for urban wind field
hydraulic is on a distinguished road
Dear all,
I plan to compute some LES simulations using OpenFOAM to study to flow field around a urban area (1km2).
I' m collecting experimental data since 1 month (3d anemometers mean+turbulence) and i would like now to run LES.
I m confused with all the models proposed by OpenFOAM, which one would you recommend me? the dynOneEqEddy is adequate?
i plan to use the cubeRootVol as the delta.
Regarding the inlet, i plan to use cyclic boundary conditions.
Regarding the mesh, i prepared one with cells 1m close to the ground/wall.
Does someone has any suggestion or tried to run LES for such case.
Thanks in advance for your help.
hydraulic is offline   Reply With Quote
Old   February 26, 2014, 09:51
Julian Langowski
Ruli is on a distinguished road
simpleFoam does work with cyclic BCs, too.
Best regards
Julian
πάντα ῥεῖ - Heraclitus
Ruli is offline   Reply With Quote
cyclic bc, pimplefoam
Cyclic boundaries in OF 21x morard OpenFOAM 25 May 13, 2013 22:35
Wrong wall distance with cyclic boundaries sebastian OpenFOAM Bugs 4 October 31, 2012 10:24
[Commercial meshers] Handling cyclic BC from gambit to openfoam for a cascade airfoil problem - OF 1.6 maverick OpenFOAM Meshing & Mesh Conversion 2 June 18, 2011 04:36
Cyclic patches and parallel postprocessing problems askjak OpenFOAM Bugs 18 October 27, 2010 03:35
cyclic BC with meshmotion fisch OpenFOAM Pre-Processing 0 October 15, 2010 05:44
