OpenFOAM and Adjoint solution
Hi everyone,
I have read about the capability in OpenFOAM to run the Adjoint "version" of the Navier-Stokes equations for shape optimization. Is there a way of just calculating the Adjoint solution so I can locate the more sensible regions in an afterbody (cartesian) wake in order to design wake stability measures? Thanks! |
Probably best to start with the 'adjointShapeOptimizationFoam' solver (a simpleFoam derivative), while maintaining alpha = 0. Beware though, adjoint simulations are notoriously unstable. Good luck! Sylvester |
Thank you Sylvester,
I'll give it a go during the weekend. Where could I find info about keeping stability under control? Thanks! |
You could look up my old posts on adjoint, they might help you a bit. Since then I haven't worked the subject anymore, so I haven't made much additional progress. regards, Sylvester |
