attempt to read beyond EOF
Like Tree1Likes
  • 1 Post By mturcios777
Old   March 21, 2014, 06:39
Default attempt to read beyond EOF
adarsh tiwari's Avatar
adarsh tiwari
adarsh tiwari is on a distinguished road
Dear All,
I am trying to solve a time dependent problem. my conditions for one of the pressure inlet is
type totalPressure;
gamma 1.4;
p0 uniform ;
value tableFile;
tableFileCoeffs
fileName "$ADARSH/rubyFiles/test19/TABLES/PRESSURE_TABLE/PRESSURE_HOUSING_INLET.dat"
outOfBounds clamp;
while initiating the solution I got the following errors:
[CODE][/Create time
Create mesh for time = 0
PIMPLE: Operating solver in PISO mode
Reading thermophysical properties
Selecting thermodynamics package
type heheuPsiThermo;
mixture egrMixture;
transport sutherland;
thermo janaf;
equationOfState perfectGas;
specie specie;
energy absoluteEnthalpy;
--> FOAM FATAL IO ERROR:
file: /home/eatin/ADARSH/rubyFiles/test19/0/p.boundaryField.HOUSING_INLET.p0 at line 67.
From function ITstream::read(token&)
in file db/IOstreams/Tstreams/ITstream.C at line 83.
FOAM exiting
I don't know what is going wrong. please help me ASAP
Thanks in Advance,
Adarsh
adarsh tiwari is offline   Reply With Quote
Old   March 21, 2014, 11:34
mturcios777's Avatar
Marco A. Turcios
mturcios777 will become famous soon enough
Does the file you are specifying have the same number of entries as the boundary has faces? What you are doing here in the code is setting the initial values on the patch to those in the file, the same as when the boundary is saved when your write out timesteps.
mturcios777 is offline   Reply With Quote
Old   March 22, 2014, 11:50
adarsh tiwari
Hi Marco,
First of all thanks for your quick response. I am very new in this field. I am not getting properly, what you are saying .
In single sentence I can say that I want to evaluate the flow pattern with the time dependent conditions.
I am giving the data in tabular form as mentioned in the User-Guide of FOAM 2.2.1.
Regards,
Adarsh R. Tiwari
Old   March 22, 2014, 22:22
Marco A. Turcios
I see. What the condition you have specified is trying to set the value over the field at the initial condition. What I think you want is to use the uniformFixedValue boundary condition, and set the uniformValue to the table you are using.
Old   March 23, 2014, 07:23
adarsh tiwari
Hi Marco,
I have attached my '0' Folder also few ones of my table files.
all other table files are in the same format.
Please tell me what went wrong.
Regards,
Adarsh R. Tiwari
Old   March 24, 2014, 11:43
Marco A. Turcios
I think I see what the problem is, but just to be sure: the files PRESSURE_HOUSING_INLET and PRESSURE_HOUSING_OUTLET are the time dependant value of total pressure that you want at those particular boundaries?
Old   March 25, 2014, 22:36
adarsh tiwari
ya, actually I have to simulate the mass flow pattern out of the pressure and temperature specified. I tried to solve the issue and gave a run.
the case files initially i prepared with the help of 'http://www.openfoam.org/version2.1.0/boundary-conditions.php', later i modified it.
I am clueless about what is getting wrong.
Old   March 26, 2014, 12:03
Marco A. Turcios
Your boundary conditions (p,T,U) look fine. The data files seem like they might be the problem. If they are similar as the files in PRESSURE_TABLE.zip, then you have to remember how to format a DataEntry of type tableFile. You can read the documentation here (specifically, the detailed description):
http://foam.sourceforge.net/docs/cpp/a02520.html
So, if I wanted (for example) as pressure that increased from 1e5 to 5e5 from 0.01 to 0.05 seconds linearly, my tableFile would look like:
    (0.0 1e5)
    (0.01 1e5)
    (0.02 2e5)
    (0.03 3e5)
    (0.04 4e5)
    (0.05 5e5)
Note that the first entry is a scalar and is always the simulated time. It must be monotonically increasing, and I think I saw some negative times in your specification, which could be messing you up. Why you have negative numbers in your time?
adarsh tiwari likes this.
Old   March 30, 2014, 14:47
Smile
adarsh tiwari
hi Marco,
It seems that my problem is solved. initially it was with file location, now i have directly written the table in the case file.
the problem i faced was :: semi-colon ';' was not properly placed, i have done that and now getting some simulations done.
Thank you, Marco!!!
Old   October 5, 2014, 20:06
Default error: attempt to read beyond EOF
krishh
krishtej23 is on a distinguished road
Hi Tiwari,
I too have the same error as you got. I checked many times about any semicolon which is missing but I didnt find any. I am unable to understand it. Please can you see the error and check the transportProperties.
Thanks in advance.
Krishna Teja.
krishtej23 is offline   Reply With Quote
Old   May 26, 2020, 02:11
Adarsh
adarshfoam is on a distinguished road
Originally Posted by adarsh tiwari View Post
Hi Marco,
Regards,
Adarsh R. Tiwari
Hi Adarsh I am also facing the same problem. did you get your problem solved
adarshfoam is offline   Reply With Quote
[General] 2 datas on one plot Akuji ParaView 46 December 1, 2013 14:06
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem Attesz OpenFOAM Meshing & Mesh Conversion 12 May 2, 2013 10:52
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 01:27
999999 (../../src/mpsystem.c@1123):mpt_read: failed:errno = 11 UDS_rambler FLUENT 2 November 22, 2011 09:46
Problem in running ICEM grid in Openfoam Tarak OpenFOAM 6 September 9, 2011 17:51
