March 21, 2014, 12:01 |
Cyclic boundary condition error
James B
Rep Power: 12 |
Dear Foamers
In order to simulate a flow in a cylinder, I am simulating this simplified in 2D by opening the mantle and connecting both sides with the help of the cyclic BC. (underside is inlet and upside is outlet). When I try to run this, it always gives the same error: (I am using OF 2.1.1) Code:
#0 Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #1 Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #2 Uninterpreted: #3 __pow_finite in "/lib/i386-linux-gnu/libm.so.6" #4 pow in "/lib/i386-linux-gnu/libm.so.6" #5 Foam::pow(Foam::Field<double>&, Foam::UList<double> const&, double const&) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so" #6 void Foam::pow<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensioned<double> const&) in "/home/OpenFOAM/platforms/linuxGccDPOpt/bin/ddtFoam" #7 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::pow<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&, Foam::dimensioned<double> const&) in "/home//OpenFOAM/platforms/linuxGccDPOpt/bin/ddtFoam" #8 in "/home/OpenFOAM/platforms/linuxGccDPOpt/bin/ddtFoam" #9 __libc_start_main in "/lib/i386-linux-gnu/libc.so.6" #10 in "/home/OpenFOAM/platforms/linuxGccDPOpt/bin/ddtFoam" Floating point exception (core dumped) Thanks for the help! |
Display Modes | |
Building OpenFOAM1.7.0 from source | ata | OpenFOAM Installation | 46 | March 6, 2022 13:21 |
Compile calcMassFlowC | aurore | OpenFOAM Programming & Development | 13 | March 23, 2018 07:43 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
checking the system setup and Qt version | vivek070176 | OpenFOAM Installation | 22 | June 1, 2010 12:34 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 06:31 |
