Cyclic boundary condition error
Old   March 21, 2014, 12:01
Default Cyclic boundary condition error
James B
james91 is on a distinguished road
Dear Foamers
In order to simulate a flow in a cylinder, I am simulating this simplified in 2D by opening the mantle and connecting both sides with the help of the cyclic BC. (underside is inlet and upside is outlet).
When I try to run this, it always gives the same error:
(I am using OF 2.1.1)
#0  Foam::error::printStack(Foam::Ostream&) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#1  Foam::sigFpe::sigHandler(int) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#2  Uninterpreted:
#3  __pow_finite in "/lib/i386-linux-gnu/libm.so.6"
#4  pow in "/lib/i386-linux-gnu/libm.so.6"
#5  Foam::pow(Foam::Field<double>&, Foam::UList<double> const&, double const&) in "/opt/openfoam211/platforms/linuxGccDPOpt/lib/libOpenFOAM.so"
#6  void Foam::pow<Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh>&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::dimensioned<double> const&) in "/home/OpenFOAM/platforms/linuxGccDPOpt/bin/ddtFoam"
#7  Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::pow<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&, Foam::dimensioned<double> const&) in "/home//OpenFOAM/platforms/linuxGccDPOpt/bin/ddtFoam"
#9  __libc_start_main in "/lib/i386-linux-gnu/libc.so.6"
Floating point exception (core dumped)
Does anyone know where this error is coming from? Or do you have to adapt the solver to use it for cyclic BC?
Thanks for the help!
james91 is offline   Reply With Quote
Building OpenFOAM1.7.0 from source ata OpenFOAM Installation 46 March 6, 2022 13:21
Compile calcMassFlowC aurore OpenFOAM Programming & Development 13 March 23, 2018 07:43
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 12:34
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
