Centrifugal pump OpenFOAM, convergence problem, ANSA model
Old   July 5, 2014, 09:12
Default Centrifugal pump OpenFOAM, convergence problem, ANSA model
RDD
RDD is on a distinguished road
Dear all,
I would like to ask your help about a convergence problem I am facing.
The model I would like to solve is the centrifugal pump made by following the ANSA tutorial CFD batch mesh pump http://docs6.chomikuj.pl/2033573733,...h_mesh_cfd.pdf
The mesh quality should not be a problem since I used the one made by ANSA.
The fvSchemes and fvSolution are the one of the OpenFOAM tutorial mixerVessel2D.
I am trying to reach convergence with the laminar model, then I will use a turbulence model.
I get pressure residuals very high and even after many iterations they do not get smaller.
I think the problem is in the boundary conditions, I was told to impose flow rate as inlet and fixedValue pressure as outlet.
I enclose my boundary conditions and all the dictionaries, I would very appreciate any clue.
Thank you,
Regards
File Type: zip centrifugalPumpANSA-convergenceProblem.zip (6.6 KB, 28 views)
RDD is offline   Reply With Quote
Suggestion for a new sub-forum at OpenFOAM's Forum wyldckat Site Help, Feedback & Discussions 20 October 28, 2014 09:04
Centrifugal Pump Simulation Problem! warex FloEFD, FloWorks & FloTHERM 29 September 23, 2014 10:27
problem for centrifugal pump transient simulation renyun0511 OpenFOAM Running, Solving & CFD 8 January 15, 2014 04:55
Problem in recompiling a turbulence model in OpenFoam 2.1.1 pascool OpenFOAM Programming & Development 6 October 3, 2012 12:03
Centrifugal pump problem Luk CFX 1 January 25, 2009 06:54
