July 4, 2018, 08:41 |
rotatingWallFunction not working properly
Osman Mirza Demircan
Rep Power: 8 |
Hi Foamers,
I am trying simulate a rotating cylinder at transonic speeds in 2D using rhoPimpleFoam of the OpenFOAM 5.0 code package. However, the simulation output is almost the same as a static cylinder. Below is my U file with the BC that I have used. I have also attached a contour showing the instantaneous Ma number. Top one is static and the bottom one is with the rotating cylinder. Am I missing something here? Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 4.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volVectorField; location "0"; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (289.25 0 0); boundaryField { inlet { type fixedValue; value uniform (289.25 0 0); } outlet { type zeroGradient; } fixedWall { type noSlip; } movingWall { type rotatingWallVelocity; origin (-0.009525 0.009017 0); axis (0 0 1); omega 104.72; // rad/s } slip { type symmetry; } empty { type empty; } } // ************************************************************************* //
Osman Mirza Demircan |
rhopimplefoam, rotating body, rotating cylinder |
Display Modes | |
potentialFoam not working properly | GAlava | OpenFOAM Running, Solving & CFD | 7 | March 9, 2021 11:34 |
Is there any institutions still working on solving N-S equations? | sharonyue | Main CFD Forum | 2 | November 11, 2015 08:23 |
what "If" condition means in rebound | brbbhatti | OpenFOAM Programming & Development | 0 | August 12, 2014 09:18 |
Flapping wing rotation in Fluent 3D not working properly | davesmith_01 | FLUENT | 1 | February 13, 2011 21:35 |
Sample utility not working properly | titio | OpenFOAM | 2 | June 9, 2010 10:45 |
