April 14, 2014, 09:58 |
MPI Error in FLuidity
Good Evening to all!
I am working on Modelling and SImulation on Multiphase Flows. I use Ubuntu as OS, and working on Fluidity Open Software. I am trying to set up my simulation and I always get this error. Please can you explain me what is the problem? cause I am still try to figure out what is happening. ------------------------------------------------------------------------- (user_name)/Research/5per4reg_left_inlet$ ../../Multiphysics/MultiFluids_Dev/bin/multiphase_prototype 5reg4per_left_inlet.mpml For triangle file with base name 5per4reg_left_inlet *** ERROR *** Source location: (Read_Triangle.F90, 81) Error message: .node file not found -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD with errorcode 16. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- (user_name):~/Research/5per4reg_left_inlet$ ../../Multiphysics/MultiFluids_Dev/bin/multiphase_prototype 5reg4per_left_inlet.mpml -------------------------------------------------------------------------- I will be happy to provide you with further details of my work. Thank you for any cooment and help! |
Display Modes | |
mpirun, best parameters | pablodecastillo | Hardware | 18 | November 10, 2016 12:36 |
MPI error | florencenawei | OpenFOAM Installation | 3 | October 10, 2011 01:21 |
Building OpenFOAM on IRIX | lakeat | OpenFOAM Installation | 7 | July 16, 2008 07:27 |
Error using LaunderGibsonRSTM on SGI ALTIX 4700 | jaswi | OpenFOAM | 2 | April 29, 2008 10:54 |
Is Testsuite on the way or not | lakeat | OpenFOAM Installation | 6 | April 28, 2008 11:12 |
